Anybody here running Koni's or Tokico D-Specs?
Just curious to see if there's any local member running a Koni insert/Tokico D-Spec and spring combo? How do you like it, and what can you compare it to? I'm bored, so I'm Looking into possible new suspension options.
I was talking to some guys on iwsti about going with an ohlins + RCE yellows and they said that was really good but pricey and they suggested the Koni inserts so I'm guessing the koni's are pretty good to be suggested as a sub for ohlins... Sorry this probably didn't help much just thought I'd throw it out there.
Car Info: '04 WRX Wagon
I'm going Sprint Springs with Tokico D-Specs soon.
They come recommended for my use (street plus Track). The guys www.turninconcepts.com said the D-Specs have a nice ride.
Car Info: 2008 Mercedes E350
Brandon, if you do street+track, I'd say stick with the SS-Ps and EDFC, you can adjust your damping depending on what you do. I'd find that the most convenient because you would have a different setting for street than you would for the track, but thats just my 2 cents
I also hear that the Tokicos ride well (from TIC) when matched with most springs available.
On a side note, if you go the coilover route, I would highly recommend trying a european valved coilover, such as KW or even AST. They tend to run softer springs with better dampeners and generally last longer.
I've done it for other cars before, and while not hard, its worth/value is dependent on your expectations. If you simply want a good dampener for a good ride, then I think the Dspec is better. But if you want to be able to rebuild and revalve, then the koni is better. Of everyone on the board, you definitely have the tools do it, though.
I think one plus of going to the koni route is also that the Konis will have better resale value once you convert your struts.
If you have an 04, then you can get the Scooby921 (click) bushings from TIC to eliminate the clunk with the dspec. It's definitely an easier solution, and I'd think the performance would be similar. But I know for a fact that the DSPECs cannot accept an aftermarket camber plate if you intend to mount the 04 tops.
So that may be a deciding factor--negative camber ftw.
TIC is working on a custom top nut to allow the D-Specs to work with Whiteline and RCE camber plates.
Since they sell D-Specs too now you'd be crazy not to get them from there since they make the spacers required for the rear on 04+ cars and they know what they are talking about. They carry some springs too.
- Andrew
- Andrew
- Andrew
- Andrew
I think you PM'ed me about this...but I'll post just in case.
I was running Koni adjustables with H&R OE Sport springs and it was a really nice setup. I recently changed the springs to OE STI Spec-C springs with my Koni's so I can stop scraping my V-Limited lip going in and out of steep driveways. Also gave me a chance to swap out my housings for powder coated ones to "pretty them up" a bit.
Someone above spoke of the TIC/Scooby921 spacers...I'm using something very similar that I've had machined at a machine shop on my Konis since the used set I bought was from a 2003 WRX and it works perfectly with my 2004+ springs and tophats.
I'd definitely recommend Koni yellows. My only complaint would be a lack of an easy way to adjust the rears without pulling the rear seats out. Tokico has a really cool adjustment extension made for the RX7 that people have been using on Subies. I even purchased a set in case I went the Tokico route (which reminds me I need to post it for sale now.) Other than that I love the Koni's. Much smoother ride than the OE shocks with the flexibility of adjustment to whatever springs you decide to use.
Good luck!
Good luck!
salvator_rizzo
08-10-2011 11:50 AM
elementliquidx2
06-01-2011 04:40 PM
