Any more suggestions on suspension components?
My car has frame damage due to a rear end collision. Unfortunately, it was so new that they wouldn't total it. I had 3k on the odometer. That's it. I feel better, I took it to a really good shop, they do really good work, but it just took them a long time.. 3 months to get the frame rail in.
So far, it's still sitting in the shop, they finally welded everything, they were cool enough to let me install the suspension components that I had bought to tighten up the frame. I was wondering if there is anything else that I might consider purchasing.
So this is what I have on an 04 wrx wagon
front sti upper mounts
rear sti upper mounts
tein s type springs
kyb agx shocks
cusco front sway bar
cusco rear swaybar
rear sway bar endlinks
rota actions
dunlop sp 9000 tires
Any suggestions to tighten the frame would be appreciated.
tein s type springs
kyb agx shocks
cusco rear swaybar
rota actions
Car Info: '03 PSM Sedan
front and rear strut tower bars will help with flex a little, but aren't a substitute for a straight chassis. you might also look into some of the Do-Luck stuff that is out there. they make a replacement subframe, floor braces and the like.
bushings: either the groupN bushing kit, or new laterel links and trailing arms with upgraded bushings (whiteline, noltec, sti, cusco). STi engine & tranny mounts. ALK's (whiteline or perrin) or STi front control arm bushings.
front strut bar is pretty much for looks, but the rear may help a bit. It should be last on your agenda IMO.
that cusco sub frame brace v2 as stated above is a good call as well.
How do you like the larger front swaybar/rear swaybar combo?
not to hijack the thread here, but on a car with well sorted suspension, the strut tower braces actually make a noticeable differance. i installed the front one a month or so ago, and noticed a small differance. i installed my rear brace the other night, and have already noticed a significant differance. if you're running STi takeoffs or coilovers, you'll notice the change. i think that the increased chassis rigidity in the rear gives me a better feel for what the rear end is up to. i drive a sedan, but due to the wagon's design the rear bar will have more of an impact on it than a sedan.
as far other suspension improvements (that don't stiffen the structural elements of the chassis) go, i'd also reccomend solid front endlinks with either pillowball bushes or hardened urethane. i found that it sharpened up the feel at the front end when i installed my Noltec front end links.
I don't mean to be an asshat, but I would have told the ins. co to take a flying ****, and had it totaled. Mileage or no, a car with major frame damage makes a good rally car or track car...not a daily driver.
Tell the ins. co that you want them to buy you a new car and you won't take 'NO' for an answer. Get a lawyer. Get a new car, that's what you insurance IS FOR....getting you a new car if yours is totaled and yours was.
JM Auto Racing
392
12-07-2015 07:00 AM
Speed Element
Engine and Drivetrain
05-13-2010 11:10 AM
Speed Element
09-30-2006 12:47 PM
Speed Element
04-03-2006 09:42 PM
