above 50 mph major shake and vibration in steering wheel, help?
Car Info: '03 PSM Sedan
i've had this happen before on other cars, and in the past its been ABS issues. if something gets stuck in a wheel speed sensor this can happen even when you're not on the brakes.
i'd take a look at all the obvious things like tires, wheels, etc. to make sure that there isn't something simpler wrong, and then take it into the dealer.
...or threw a wheel weight.....or bent a wheel on that last pothole....or got a sihtty diaper stuck to your tire(happened to me once...really)
Car Info: '08 GT3/'08 Cayenne Turbo/'02 WRX Sedan/'95 E36 M3
yeah.. i've had this happen to me
like above 60 the steering shook violently
then above 80 it was fine haha
turns out - just some wheel imbalance
scoobie, could you post a follow up? i'm having similar prob. i hope it's just wheel balance fix...
i also have a lot of road/tire noise (i'm at 80k mi.) is it possible that the vibration is due to bad alignment or worn out wheel bearings?
I got my wheels balanced and that seems to work. I think my bearings are going too but i'm going to wait little longer to replace them. dont forget to rotate your tires. it made the car whole lot quieter
