Zeal Function XS Coilovers for Legacy GT!!
Old 07-26-2006 | 02:51 PM
Speed Element's Avatar
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
Got 2 sets of 2005-06 Legacy GT Sedan/Wagon Zeal Function Xs Coilovers in stock and ready to go!
Zeal Function XS Coilover For the next generation street user, we’ve developed the Function-Xs Series. The Function-Xs is now born. With advanced damping capabilities in effect, our efforts have recently focused towards our new “X-Coil Hyper Spring”. Through consistent and progressive research and experience, we’ve improved spring quality to achieve an even smoother and more responsive feel and ride. The ability to grasp precise road data has improved. The X- Coil spring achieves exactly this. Our Dynamometer Data proves this with stable rebound and compression levels (within a 0.1 Meter Per Second range) for level travel at very low speeds, very high speeds, and everything in between. By keeping very detailed, precision spring motion in mind, we are able to set the shock’s piston valving to superior levels. The combination of the shock and spring is superior. Our Linear Spring Motion with no Friction Loss is superior and the shock can be adjusted precisely (Function-Xs includes 6-Way Damping Adjustability). Lightweight aluminum upper mounts, spring seat preload and spring seat lock, height-adjustable lower brackets and lock seats (for non-strut type applications) include a durable, Alumite finish for rust proof characteristics. Steel shell casing includes a special chromate plating for rust proof characteristics also. Adjustable brackets are newly designed and slender. Driving feel is amazing for the street-user. MacPherson Strut-Type are specifically systems are produced as an inverted-monotube type. Street Spring Rate Only: Front: 8kg/mm Rear: 6kg/mm
MSRP: $2460, Please PM me for Blow Out Pricing!
Thank you for looking!!
Calvin
510-226-8822
Speed Element
05-10-2016 04:11 PM
QualityOregon
09-26-2006 04:55 PM
Ditchhanger
Hawaii Classifieds
09-24-2006 12:41 AM
Z3coupe
16
01-23-2006 02:34 AM
Quick Reply: Zeal Function XS Coilovers for Legacy GT!!
