Zeal Function Xs $2440.00 Installed!! Project Mu Rotors $625.00 And More!!
Old 12-01-2006 | 06:03 PM
gruppe-s's Avatar
Hey guys, we have 3 sets of Zeal Function XS in stock and ready to ship. At the moment we are offering free installation with the purchase of these coilovers. These coilovers are for all 05-06 STI's and Endless USA has been gracious enough to offer us FREE coilover modification so these coils will also work for all 02-06 WRX's. Pricing on the Function XS will be $2440 with free installation ($150 usually). Please PM for pricing if you would like these coilovers shipped to you. If you have any other questions please feel free to call or PM me. Thanks!
$2440 (Free Installation)
-8k (front) 6k (rear)
-05-06 STI
-02-06 WRX
Street Spring Rate: FT: 8kg/mm RR: 6kg/mm
Here is some information about these coilovers:
For the next generation street user, we’ve developed the Function-Xs Series. The Function-Xs is now born. With advanced damping capabilities in effect, our efforts have recently focused towards our new “X-Coil Hyper Spring”. Through consistent and progressive research and experience, we’ve improved spring quality to achieve an even smoother and more responsive feel and ride. The ability to grasp precise road data has improved. The X- Coil spring achieves exactly this. Our Dynamometer Data proves this with stable rebound and compression levels (within a 0.1 Meter Per Second range) for level travel at very low speeds, very high speeds, and everything in between. By keeping very detailed, precision spring motion in mind, we are able to set the shock’s piston valving to superior levels. The combination of the shock and spring is superior. Our Linear Spring Motion with no Friction Loss is superior and the shock can be adjusted precisely (Function-Xs includes 6-Way Damping Adjustability). Lightweight aluminum upper mounts, spring seat preload and spring seat lock, height-adjustable lower brackets and lock seats (for non-strut type applications) include a durable, Alumite finish for rust proof characteristics. Steel shell casing includes a special chromate plating for rust proof characteristics also. Adjustable brackets are newly designed and slender. Driving feel is amazing for the street-user. MacPherson Strut-Type are specifically systems are produced as an inverted-monotube type.
*Custom spring rates available at no additional charge
All CA residents, please include 7.75% sales tax
POJECT MU 05-06 STI 2 PIECE ROTORS!!
SALE PRICE: $625.00 SHIPPED!!!
ONLY 1 AT THIS PRICE!!!
SPRING / SWAY BAR PACKAGE!! (STAGE 1)
4x STI Pink Springs:
-1" lowering all around
-Better matched spring rate for stock struts
2x Cusco STI Swaybars
-22mm Front
-22mm 3-way adjustable Rear
-2004+ Cars only (WRX available)
Great >combo< for the street!
Priced at $529 shipped! (Price includes Pink Springs, Front Sway Bar, Rear Sway Bar - 3 pcs)
Only 1 set avaliable at this price
Need Install? $669 Installed! (Plus Tax)
Cusco Titanium Tower Bar
-Genuine Japanese aerospace grade titanium
-TIG welded
-Ultra-light construction
$299 Shipped!!
Aerosync Front Carbon Fiber & Cusco Rear OS Tower Bar Combo
-Aerosync Carbon Fiber Tower Bar (Genuine Carbon Fiber)
-Cusco OS Rear Tower Bar
$299 Shipped!! (for the pair)
Cusco 21mm Front Sway Bar & 22mm Rear Sway Bar (Combo)
-21mm Front fixed sway bar
-22mm Rear 3 point adjustable sway bar
-02+ WRX Fitment
-Great setup for improved handling
$279 Shipped!! (for the pair)
Cusco V2 Lower Arm Bar
-Substantially improves chassis rigidity
-Compatible with 3" downpipes
$145 Shipped!!
STOPTECH 332mm 4-piston brake kits
-332x32mm Caliper
-Slotted 2pc Rotors
-Front SS Brake Lines
$1599 Shipped!!One set at this price!
It's no secret that the STI has some wheel bearing issues. Less well known is the root cause. According to STI engineers, one of the key contributors of wheel bearing failure is the heat associated with high performance driving. So we are offering a good solution. 2-piece floating rotors will substantially reduce the heat transmission from the super hot brake caliper & rotor to the wheel bearing. This reduction in heat will help prolong the life of your bearings as well as improve braking and even quarter mile times with the reduction of rotational mass!
Performance Friction 2-piece floating rotors & high performance pads
-Floating 2-piece design substantially reduces heat
-Compatible with factory Brembo calipers
-4.4lbs weigh reduction means HUGE reduction in rotational mass
-Packaged with Axxis Ultimate
-Available in 5x100 or 5x114.3 for 2004+ STI
$699 Shipped!!! (front pair only)
WHITE LINE SWAY BARS
STI Front 24mm Adjustable $165 Shipped!!
WRX Front 24mm Adjustable $165 Shipped!!
WRX Rear 24mm Adjustable $165 Shipped!!
WRX Rear 24mm Fixed $145 Shipped!!
WRX Front 27mm Adjustable $215 Shipped!!
Once again, if you have any other questions please feel free to call or PM me. Thanks!
-Erik
Old 12-06-2006 | 06:29 PM
gruppe-s's Avatar
Talking
bump
Speed Element
05-10-2016 04:11 PM
richy_21
06-17-2012 05:32 AM
gruppe-s
12-07-2006 03:15 PM
944 turbo guy
11-08-2004 07:38 AM
Quick Reply: Zeal Function Xs $2440.00 Installed!! Project Mu Rotors $625.00 And More!!
