Stance Coilovers!! AL+, GR+, LX+! Pro models too!
Former Sponsor
Car Info: Evo X, 04 STI, 335i, Fit
We offer some great coilovers from Stance. With a wide range from street to track applications so there's something for everyone!
Stance GR+
GR+ is Stance's main flagship line of coilovers. Oversize diameter shocks allow large pistons for ultimate performance and response. 15-way adjustable damping allows the driver to tune the shocks for any conditions and handling characteristics. With huge range of adjustment that can be felt and seen, GR+ offers serious performance for all levels of drivers. GR+ coilovers are built with highest quality materials and tolerances to ensure durability and performance.
8k/6k Spring Rates
* Adjustment **** 15-Way Damping Adjustable
* Upper Pillowball Bearing Adjustable Camber Uppermount
* Upper Pillowball Bearing Pillowball Uppermount
* Spring Cold Wound Linear Spring
* Monotube Inverted Monotube Shocks
* Boot Dustboot
* Collar Aluminum Collars & Upper Mounts
* Bracket Height Adjustable Lower Bracket
$PM for either 02-07 WRX/04 STI or 05-07 STI
Stance GR+ Pro
GR+Pro coilover has all the features of the GR+ but adds the benefit of a helper spring. The helper spring allows the shock piston to be placed in the optimal position within the shock body, increasing rebound stroke, and maximizing articulation on cars with minimum suspension travel.
SSD also availible with 11k/9k Rates! (add $56)
Stance AL+ Pro
AL+Pro has all the features of the GR+ Pro, but uses an anodized forged aluminum shock body. This increases anti-corrosion properties while reducing unsprung mass, enhancing all aspects of performance without any drawbacks.
8k/6k Spring Rates
* Adjustable Camber Uppermount
* Pillowball Uppermount
* Cold Wound Linear Spring
* Inverted Monotube Shocks
* Dustboot
* Aluminum Collars & Upper Mounts
* Height Adjustable Lower Bracket
* Helper Spring
Stance LX+
The LX+ is designed for the enthusiast that wants greater performance than their standard dampers without sacrificing ride comfort. The LX+ uses twin-tube technology to give a unique, luxurious ride quality. 15-way adjustable damping allows the driver to tune the shocks for any condition or handling characteristic.
7k/5k Spring Rates
Give us a call to order or check out our website for more! CA residents add 9.75% sales tax.
Stance GR+
8k/6k Spring Rates
* Boot Dustboot
Stance GR+ Pro
Stance AL+ Pro
8k/6k Spring Rates
* Dustboot
* Helper Spring
Stance LX+
7k/5k Spring Rates
Former Sponsor
GR+ and GR+ Pro for the GRB chassis are in stock! 08+ STI owners need to get these! They are less expensive too!!
9k/7k Spring Rates
-15-Way Damping Adjustable
-Front Camber uppermount
-Inverted Front shocks
PM for pricing!!
9k/7k Spring Rates
PM for pricing!!
caffeinefr3e
03-22-2010 05:18 PM
Cappx
05-11-2004 09:30 AM
