RCE deals....more like STEALS! RCE Wagons + Konis $799 shipped! Cusco, GTSpec, etc.!
Old 03-07-2008 | 12:18 PM
Racecomp Engineering's Avatar
Former Sponsor
Car Info: every subaru ever
Racecomp Engineering Regular Guy "Black" Springs
We really like these. Mild drop, big bump in spring rate, big change in handling for STi owners. Pretty good ride quality as well.
$329 shipped!!!
Price includes shorter replacement bumpstops. Sale for a limited time ONLY!
Due to increasing materials costs, shipping costs, and the weakening US dollar, Ohlins retail prices went up considerably with the start of 2008.
Retail is now set at $2250 for the Ohlins Fixed Perch Struts.
BUT Racecomp Engineering will continue to offer the Ohlins FP Struts at our usual price of $1949 shipped!
Ohlins Fixed Perch Struts with
RCE Black "Regular Guy" Springs or RCE Yellow Springs
$2229 shipped!
Front and Rear Group N Strut top mounts
$2579 shipped!
Front Whiteline MAX-C Camber Plates and Rear Group N Strut top mounts
$2769 shipped!
Whiteline 24mm adjustable front and 24mm adjustable rear swaybars
Kartboy front and rear endlinks
$3349 shipped!
CALL 410-579-1501
Former Sponsor
In 2007, RaceComp Engineering answered the call from many Impreza Wagon owners by designing and producing a performance lowering spring designed specifically for Wagons with upgraded struts.
The result is a performance lowering spring with rates perfect for users with Koni Inserts in Wagon strut bodies. Thus, the end user gets none of the usual camber loss from switching to different struts.
RCE Wagon Springs with Koni Inserts
$799 SHIPPED!!!
Yes, $799 shipped. Our regular price on the RCE Wagon Springs is $339 and Konis are usually around $700. So that's a savings of.....a lot.
Why? we just have a massive overstock of RCE Wagon Springs and need your help making room at the warehouse!
Clearing out some parts here at RCE....need to make room for the 997 GT3, the 7 post shake rig, the shock dyno, the candy machine that makes magic candy out of thin air....
WRX OEM Clutch Kit
includes:
Clutch Cover
Disc
Flywheel
throwout bearing
$615
STi Arai Performance Struts and JDM Pink
2005+ STi fitment ONLY
does not clunk!
less then a year old
4 clicks of damping adjustment
http://www.rcephotos.com/photos/albu...0691.sized.jpg
$999
JDM STi Pink Springs
20mm drop front and rear
257/217 rates
$250
STI Group N 5 speed tranny mount
$60
Call 410-579-1501
-drew
Old 03-07-2008 | 12:19 PM
Former Sponsor
Front and rear Group N's
$1164 shipped!
Front Whiteline Camber Plates
Rear Group N's
$1344 shipped!
CALL 410-579-1501
This won't last long!
Former Sponsor
Stoptech 2 pc. Rotors for STi Front
$675 shipped
DBA 5000 2 pc. Front Rotors with DBA 4000 Rear Rotors
$1081 shipped for a front and rear set
DBA Slotted Street Rotors Front and Rear Set
$505 shipped
Old 03-07-2008 | 12:20 PM
Former Sponsor
Stoptech BBK for STi
$1889 shipped!
Racecomp Engineering Kool Brake Kit
This kit was designed to cool and vent the braking system, thus reducing rotor temperatures. Initial testing at Summit Point Raceway showed up to a 200° F drop in rotor temperature when using aggressive pads. Testing was done with Pagid Blue RS-42, Pagid Yellow RS-19 and the new RS-29 brake pads. Designed to work with both stock STi rotors and any aftermarket 2 piece rotor, this kit is available now.
The Kool Brake Kit includes 12 feet of high quality, motorsport grade, high temperature hose far better then other options on the market. There is no need to upgrade. Stainless steel hose clamps are also included.
The RaceComp Engineering Kool Brake Kit is now exclusively offered in dry carbon fiber to improve unsprung weight savings. The spindle ducts are considerably lighter then the OEM dust shields that are replaced during installation.
Special intro price of $339 for the new Carbon Kool Brake Kit!!!
Current applications are 2004-2007 STi.
2008 WRX and 2008 STi applications coming soon!
410-579-1501
Old 03-07-2008 | 12:21 PM
Former Sponsor
__________________________________________
Racecomp Engineering Tarmac Coilovers
Racecomp Engineering Tarmac II Coilovers for Subaru Impreza
Racecomp Engineering Tarmac 2 coilovers are comprised of stainless steel dampers mated to linear race springs, incorporating a 2 way design with separate compression and rebound adjustments, motorsports level spring rates, composite locking perches with safety perches added, piggyback reservoirs on all front dampers, and will feature a limited lifetime warranty. Racecomp Engineering chose KW Suspension to co-brand the Tarmac 2 coilovers due to their remarkable racing heritage, consistent and impressive build quality, and phenomenal presence and support in the United States.
Racecomp is happy to announce the option of having the RCE Tarmac 2 coilovers fully assembled with either Group N strut top mounts or RCE Camber Plates and Rear Pillowball mounts.
Available for:
2002 - 2007 Subaru Impreza STI, WRX sedan, WRX Wagon, and 2.5RS
1993 - 2001 Subaru Impreza Coupe, Sedan, and Wagon
$1939 shipped
With Group N strut top mounts front and rear - $2249 shipped
With RCE Camber Plates and RCE Rear Pillowball Mounts - $2699
shipped
Racecomp Engineering Tarmac I Coilovers for Subaru Legacy
Following the successful release of our coilovers for Subaru Impreza, Racecomp Engineering decided to extend their coilover line to include 2005+ Subaru Legacy. Featuring the same stainless steel technology, limited lifetime warranty, and KW quality as the Tarmac II’s, these coilovers were designed with linear spring rates and valving that mates perfectly for the Subaru Legacy street/track driver.
Available for:
2005 - 2008 Subaru Legacy GT, Spec B, and 2.5i Sedan and Wagon
$1399 shipped!
__________________
Call us for an appointment for installation
www.racecompengineering.com ---
www.GTWORX.com
Cobb - SwiftWhiteline - Cusco - Alpinestars - Prodrive
Ohlins - Moton - KW - Bilstein - STi - Pagid - Ferodo - Piloti
6360 Unit J South Hanover Rd.
Elkridge, Maryland 21075
410-579-1501 Phone
443-370-9000 Mobile
Former Sponsor
Racecomp Engineering Camber Plates and Pillowballs
Racecomp Engineering Lowering Camber Plates
These front camber plates were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs as they lower any car by 3/8" WITHOUT sacrificing suspension travel.
Available for:
2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS
$439 shipped
Racecomp Engineering Non-Lowering Camber Plates
These front camber platers were designed to be used with a conventional spring, lowering spring or coilover. Made of aircraft grade T6 7075 alloy, these units alow up to -3 degrees camber. These come anodized in motorsport gold and work very well with lowering springs. These do not lower or raise the car, and DO NOT sacrifice suspension travel.
Available for:
$439 shipped
Racecomp Engineering Rear Pillowball Mounts for Impreza
Made with the highest quality available aircraft grade 7075 T651 aluminum and using a new extra heavy duty spherical bearing, these pillowball mounts will be up to the task of both heavy track and street duty. These solid mounts provide quicker reactions, more feedback, and a more direct feel from your suspension. Our Rear Pillowball Mounts were developed specifically to provide a solution for Racecomp Engineering Tarmac II coilover users looking for the maximum possible performance out of their coilover system.
Available for:
2002 - 2007 Subaru Impreza WRX, STi, and 2.5RS. Fits coilovers only.
$389 shipped
Old 03-07-2008 | 12:22 PM
Former Sponsor
GTSpec Braces
$165 shipped -
GTSPEC FRONT Type D Strut Brace
call for carbon and ti versions!!!
$155 shipped - GTSPEC REAR Type F Strut Brace
$155 shipped - GTSPEC REAR Type F Strut Brace for WAGON
$215 shipped - GTSPEC Fender Reinforcement Braces
$155 shipped - GTSPEC 4 Point Front Ladder Bar
$205 shipped -
GTSPEC Front Lower Tie Brace
$655 shipped -
GTSPEC Subframe Reinforcement Brace (3 piece set)
$185 shipped -
GTSPEC Rear T Brace (2 piece set)
CALL 410-579-1501 to order!!!
RCE
Former Sponsor
Cusco Braces
$154 shipped - Cusco Front Type-OS Strut Tower Bar
$154 shipped - Cusco Rear Type-OS Strut Tower Bar
$155 shipped - Cusco Lower Bar Version II
$129 shipped - Cusco Rear Subframe Brace
Old 03-07-2008 | 12:23 PM
Former Sponsor
Whiteline Suspension
Whiteline Adjustable Swaybars
27mm Front Adjustable Sway Bar - $209 shipped
27mm Rear Adjustable Sway Bar - $209 shipped
24mm Front Adjustable Sway Bar - $189shipped
24mm Rear Adjustable Sway Bar - $189 shipped
$309 shipped - Whiteline Max-C Camber Plates
$319 shipped for motorsports/coilover version
$191 shipped - Whiteline Anti-Lift Kit
$205 shipped for motorsports version
$184 shipped - Whiteline Roll Center Kit
Swift Springs
$279 shipped - Swift WRX Springs
Cusco
$259 shipped - Cusco Motor and Tranny Mounts
GTSpec
$184 shipped - GTSPEC Rear Differential Mount
Old 03-19-2008 | 10:40 AM
Former Sponsor
WRX OEM Clutch Kit
includes:
Clutch Cover
Disc
Flywheel
throwout bearing
$615
does not clunk!
$999
257/217 rates
$250
$60
Call 410-579-1501
-drew
gruppe-s
Engine and Drivetrain
01-08-2007 03:30 PM
gruppe-s
10-11-2005 12:56 PM
gruppe-s
10-06-2005 04:38 PM
gruppe-s
09-14-2005 06:41 PM
gruppe-s
09-14-2005 06:39 PM
Quick Reply: RCE deals....more like STEALS! RCE Wagons + Konis $799 shipped! Cusco, GTSpec, etc.!
