Poltech Lateral Links SUSPENSION SYSTEM UPGRADE!!!!
Old 02-02-2006 | 07:41 PM
500whp.com's Avatar
Car Info: 03 Evo, 88 RX-7 T2
Talking Poltech Lateral Links SUSPENSION SYSTEM UPGRADE!!!!
Lateral Links - Adjustable w/ Aluminum Pillow-ball Bearings: 795.00 Shipped
Model: '02+ WRX and '00+ RS
-Full aluminum construction, that includes hardware, spacers, and spherical (pillow ball) bearings, weights only 5.9 lbs/set vs. stock weight of 8.7 lbs.
Full anodized aluminum construction ensures that the links will retain their looks and performance and will not corrode, superior corrosion resistance make it ideal for areas where salt is used on the roads in winter.
-Spherical bearings, unlike links with bushings, will not deform under load so your rear suspension will be much more responsive and, at the same time, they freely rotate up and down so that the rebound speed is much faster that with links with bushings.
-They use 7075 aluminum alloy for all major parts, this is the strongest aluminum alloy available
-Their lateral links are adjustable (+/- .5 inch) so you can use them to set camber and toe as well as suspension width, as much as 1.5 deg. of camber adjustment on each side is possible
-Specially designed adjustment nuts (tools included) allow for length adjustment without the need to remove the links.
-The bearings are fully sealed, lubricated and Teflon lined for lifetime of trouble free performance
-Set includes 2 front and 2 rear lateral links, tools used with adjustment nuts, and instructions
Lateral Links - Adjustable w/ Aluminum Pillow-ball Bearings: 795 Shipped
Model: 04+ STi
-Full anodized aluminum construction ensures that the links will retain their looks and performance and will not corrode, superior corrosion resistance make it ideal for areas where salt is used on the roads in winter.
MORE TO BE UPDATED SOON
500whp.com
02-04-2006 12:02 AM
Egan
12-26-2003 03:41 PM
vapor
07-16-2003 09:44 AM
Andersonwrx
02-05-2003 05:04 PM
Quick Reply: Poltech Lateral Links SUSPENSION SYSTEM UPGRADE!!!!
