PolTec Front End Link SUSPENSION SYSTEM UPGRADE
Car Info: 03 Evo, 88 RX-7 T2
Front End Links - Aluminum: 109.00 Shipped
Models: '00+ RS, L, '02+ WRX Wagon, '95-'00 Legacy, '02+ WRX Sedan and '04+ STi
- Direct replacement for stock links, maintains stock length and is more than three times as strong as stock units
- Features asymmetrical bushings for greater sway bar clearance
- Unlike the links with bushing offered by other manufacturers, our bushings COMPLETELY eliminate play between the sway bar (anti-roll bar) and control arm for instantaneous response of your suspension without noticeable increase of vibrations and harshness.
- Features spherical bearings with Teflon™ lining for superior response and durability, self lubricating for lifetime of quiet operation, red anodized aircraft ALUMINUM alloy body offers strength and corrosion resistance.
- Spherical bearings allow for resistance free pivoting unlike links with rubber bushings that subject the sway bar and suspension to sideways loads
-Includes new hardware and installation instructions
-Allows for length adjustment to eliminate sway bar preload (helps level the vehicle), a must for cars with coilovers
Front End Links - Steel: 89.00 Shipped
-Direct replacement for stock plastic links, maintains stock length
-Unlike the links with bushing offered by other manufacturers, our bushings COMPLETELY eliminate play between the sway bar (anti-roll bar) and control arm for instantaneous response of your suspension without noticeable increase of vibrations and harshness
-Features spherical bearings with Teflon™ reinforced lining for superior response and durability, self lubricating for lifetime of quiet operation
-Spherical bearings allow for resistance free pivoting unlike links with rubber bushings that subject the sway bar and suspension to sideways loads
-Improves vehicle handling (makes it more neutral and reducing roll) by eliminating the play caused by the stock rubber bushings. Allows for length adjustment to eliminate sway bar preload (helps level the vehicle), a must for cars with coilovers
XkrazyAsianX
03-02-2006 12:45 PM
500whp.com
02-03-2006 11:02 PM
