Ksport coilovers in-stock!
please visit the link to order:
http://streetrays.com/ksport/b-10293.aspx
kontrol pro kit, features:
* 36-way adjustable dampening
* Made from high quality 6061 Aluminum with T6 for increased hardness
* Compression/Rebound adjustable
* Adjustable spring perch for height adjustment
* Adjustable body allowing maximum suspension travel
* Pillow Ball Top Mount w/ adjustable camber (not available for some models)
* Monotube High Pressure Design reduces oil leakage
* Electroplated body for protection from corrosion and rust
* One Year Limited Warranty
GT pro kit, features:
* Inverted steel shock absorber for durability
* Lower center of gravity and higher chassis rigidity
* Designed to reduce friction for cooler shock oil temperature
* Inverted design like vehicles in WRC and all JGTC cars
we'll have to check with K-sport. if you want, please do email support@streetrays.com we'll get you a price and availability. thank you.
zulatron
09-19-2007 10:59 AM
UTWRX
10-20-2005 02:54 PM
