Brake Combos - DBA, Endless, Brembo, Porterfield, etc.
DBA 2 Piece (5000 Series) Replacement Rotors - Front Pair -
$749 Shipped for 04 / 05+ STi!!!
$569 Shipped for 02-05 WRX / 06+ WRX!!!
*2-Piece design allows weight savings for increased cooling capacity and handling dynamics.
*Patented "Kangaroo Paw" ventilation design.
*Center hat made from light-weight 6061-T6 aircraft grade aluminum (re-usable).
*Directional slotted design.
*NAS (National Aerospace Standard) bolts and lock nuts.
*Thermal Stability Profiling paint pre-applied.
*Available in slotted, blank, or slotted and crossdrilled.
*Hats available in black, blue, red, and gold.
DBA 2 Piece (4000 Series) Replacement Rotors -
$379 Shipped for 04 / 05+ STi Front!!!
$379 Shipped for 04 / 05+ STi Rear!!!
$259 Shipped for 02-05 WRX / 06+ WRX Front!!!
$239 Shipped for 02-05 WRX / 06+ WRX Rear!!!
Endless Vita Nouva – 02+ WRX/04+ STi, F/R
Vita Nuova is Endless' most popular, entry level compound for the everyday sports-minded, city driver concerned especially with safety. For the spirited driver, factory brake pads may feel stressful at times. If so, this compound will appeal to you. This pad focuses on safety and stopping power.
$99 shipped for F or R, $190 shipped for F and R!!!
Endless SSS Pads - 02+ WRX /04+ STi, F/R
These pads are an excellent choice for the agressive street driver. They are non-metalic so they are rotor friendly and dust is minimal. The SSS feature a high friction coefficient so they are suitable for short weekend track stints but are not applicable for heavy track use.
$152 shipped for F or R, $300 shipped for F and R!!!
Endless CC-A Pads - 02+ WRX/04+ STi, F/R
The emergence of heavier and more powerful vehicles has led to the development of the ultimate semi-metallic, street compound with impressive pedal feel and the lowest levels of disc rotor abrasion, noise, and dust levels amongst the CC line-up. Perfect within the street temperature and speed range with a high level of braking force and controllability.
Endless CC-X Pads - 02+ WRX/04+ STi, F/R
Proven to perform well on both street and track conditions, this original formula, ceramic carbon metal base compound has the ability to perform for a wider range of users. For the street where low temperatures are frequent, this pad performs well causing less damage than most semi-metallic pads. Usually, semi-metallic pads sacrifice initial response to perform better at higher temperatures, but the CC-X is able to do well at initial response as well. At higher temperatures, pedal feeling responds well while maintaining controllability with a stable coefficient of friction.
$250 shipped for F OR R, $435 shipped for F and R!!!
Porterfield R4-S Brake Pads (carbon kevlar)
These pads are a good balance between race pads and street pads. The Porterfield R4-S’ are unique because they’ll withstand 20 minutes of track time with no fade (they so not fade at temperatures up to 1,100 degrees F) but at the same time, they will work fine when cold and they’re very rotor friendly (as well as being very slow wearing). The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. The R4-S compound also has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brakes material.
Good for autocrossing, drivers schools, weekend track sessions, solo events, and rallys.
04+ STi - $199 shipped for F, $269 shipped for F and R!!!
02+ WRX - $89 shipped for F, $149 shipped for F and R!!!
03-05+ WRX - $108 shipped for F, $169 shipped for F and R!!!
Brembo Sport Replacement Rotors (Drilled or Slotted) - F/R - 04 STi only
~Brembo Sport slotted brake rotors are for drivers who want to improve the
looks and performance of their vehicle's original braking system without
having to change additional brake components.
~Brembo Sport slotted and drilled brake rotors provide excellent stopping
power in everyday traffic, as well as high performance street and track
driving.
~Brembo Sport slotted brake rotors match the vehicle's original equipment
rotor's dimensions and are fully compatible with its hubs, brake calipers
and road wheels.
$394 shipped for F, $375 shipped for R!!!
OK, now for the packages:
04 STi Front:
1) Porterfield R4-S Pads F, Brembo rotors F, Goodridge SS lines F+R: $675 shipped!!!
2) Endless SSS Pads F, Brembo rotors F, Goodridge SS lines F+R: $655 shipped!!!
3) Porterfield R4-S Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1110 shipped!!!
4) Endless SSS Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1180 shipped!!!
Special Brake Packages for the WRX:
Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes.
Porterfield R4S Pads + Goodridge SS Lines + Motul 5.1 Fluid
*The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp.
*The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects
*2 Pints of Motul 5.1 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff.
All 4 Corners for 02 WRX - $299 Shipped
All 4 Corners for 03+ WRX - $319 Shipped
If there's a package that you'd like and it's not listed, please don't hesitate to ask for pricing.
Thanks,
Mark
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Mark
Price including shipping: $XXXX
Shipping address.
*CA Residents please include the necessary sales tax (7.25% or 8.75% for Alameda County)
driving.
and road wheels.
04 STi Front:
Thanks,
Mark
We Accept Paypal!
product name: XXXX
sales rep: Mark
Shipping address.
GST Motorsports
07-18-2012 01:18 PM
gruppe-s
09-07-2006 01:14 PM
gruppe-s
03-22-2006 05:34 PM
gruppe-s
03-22-2006 04:48 PM
gruppe-s
01-21-2006 12:31 PM
