Will warrenty cover throw out bearing?
Car Info: '00 RS, Subrosa Letum
Does anyone know? I have heard some say that "premature" clutch wear may be covered but what about a squeeky throw out bearing. The clutch does not need replacement yet but the bearing does.
It's not your bearing most likely. Check out this link, it's probably just your slave cylinder/clutch fork squeaking.
update: I wasn't able to take my car to the dealer due to it being in the body shop, so no news on warrenty coverage.
So, since I'm already close to 60k miles and this is the same clutch that I learned to drive with I have decided to just replace everything.
What is a good flywheel/clutch combo for a GC RS?
Paying for labor is not an option so how difficult would it be for me to do it myself?
I have an Exedy clutch and flywheels combo in my RS, I love it. The install is fairly involved, especially if you don't have access to a lift. Subaru Specialists quotes about $400 for a clutch replacement, so I would recommend letting them do it if you can.
I had to replace my wheel bearing, and no its not under warranty, however id recommend just getting the wheel bearing from a subaru junkyard I got mine for $60 and installed it myself
DougZ
06-10-2003 12:48 PM
