When to start using Synthetic oil?
I have an o6 STi and i heard that your not supposed to use synthetic till 36k miles because of break-in... when did it take 36,000 miles for break-in process??? Did i miss something here?
Car Info: WRX --> RX-8--〉E93
around 10k is good enough, but its better to 2 times, when u let all ur old oil out n put synthetic in, then run it for 5 mins, then let it all out again, n put new oil in. its more work, but worth it
If you want to switch to synthetic, do it whenever you feel like it. Everyone will tell you something different. The consensus is 10-20K miles. If you really want to know how the motor is responding to oil, send a sample of your used oil to a lab for an oil analysis. BTW I switched to redline synthetic after break in (3K or 3750) on my 02 wrx.
I switched over to Mobil at 10k.
wimpreza: if you want to save some money, find a local mechanic you trust and supply your own oil/filter. You can get a 5qt bottle of Mobil 1 synth from Wal-Mart for ~$21 and the filter from Subaru is only $9 or so.
evsoul
18
10-26-2006 12:44 AM
HoneyRex
12-25-2005 10:03 AM
Zoeb2s
58
12-04-2002 06:12 PM
