When Piston rings fry
Car Info: i got a STi, w/ Helix up pipe and helix racing downpipe
im worried about my piston rings, because i have to add oil every 1000 or so mile. i mean i know how a turbo charged car can eat oil but my car is burning oil way way too fast. anyone had a similar problem? or would know how to go about finding out what the real problem is?
my car is a 2004 STi with injen intake helix up/downpipe, GT spec cat-back
as you can see no serious mods so whats the deal with my car? why is it needing oil every 1000 miles, i dont mean add one quart... i mean its all gone. all but one quart
plz hlp, thanks
plz hlp, thanks
Subaru actually considers up to 1 qt/1000 miles to be within the normal range for oil consumption. Most other manufacturers follow this spec as well. Since you are still under warranty, if you think your car is using oil excessively you can have the dealer perform an oil consumption test, they will change the oil and have you return at regular intervals to check the level. If the engine is indeed found to be using more oil than specified they will repair it. However you should be prepared for the possibility of the dealer giving you a hard time about the mods you have done.
Also are you using the proper viscosity of oil as recommended in your owners manual? Failure to do so can result in higher than normal oil usage.
Oh and BTW why did you replace the uppipe on your STi, it's already catless from the factory?
ok so this is it, on dec 29 i had 20475 miles, now i have 21864 and thats a difference of 1389... and i am on low for oil... im guessing about 3-4 quarts are burnt up. oh ya, and as for the mods, im taking my car back to stock because i dont want to risk voiding the warranty
and mulder, yea i installed the helix catless downpipe, and the stock downpipe has one cat in it i think, and theres one pre cat in the up pipe
Car Info: '05 Crystal Grey Metallic WRX Sport Wagon
There's only one quart between the full and empty marks on the dip stick (it is on almost all cars at least, I just assumed it is on WRXs too...). So if you're going from the full mark to the empty mark in 1000 miles, that's 1qt/1000mi...'normal' according to Subaru.
Originally Posted by Aelon
acualy theres oil on the dipstick but below the L
so im going to have the dealer run the test on it to be certain
Oh and only the WRX's have a cat in the upipe.
WRX= 3 cats (down pipe, mid pipe and up pipe
STI= 2 cats ( downpipe and the mid pipe)
Originally Posted by Mulder
Above is correct, you replaced your uppipe for nothing.
Teddy
08-07-2004 12:35 PM
