tires exploding?
tires exploding?
when i was going about 130 one day i started to hear a very loud high pitch noise coming from the back of the car. should i worry about it? it stopped after i brought it back down to 125 and i never heard it at regular speeds. anybody know what it was?
What are our tires rated at? I consentantly drive about 80-90 mph to and from work... Should I be worring about tires blowing out...?
Thanks,
-Nigel
Thanks,
-Nigel
Thanks,
-Nigel
Thanks,
-Nigel
Daredevil,
How much do new tires run? Are they many hundreds of dollars? How long do the re92's usually last?
-Nigel
Daredevil,
-Nigel
My tires were expensive, but I have 17's. 16" tires aren't as bad. Check out www.americastire.com or www.tirerack.com
Check what the speed rating on the tire is. Every tire manufacturer uses the same speed rating, it's an industry standard. The stock RE92s are good up to 140 if I'm not mistaken. They should have a speed rating of 89H. Check around the tire's side wall, every tire has to have one. Even my dad's '92 Ford Ranger has the speed rating. There should be a tire warranty booklet in the case with all the warranty issue cards and the owner's manual. It gives the speed ratings for tires.
