Timing belt and other belts
Car Info: 02 Silver WRX sedan. Eibach springs, Blitz NUR cat back, Rota 17" Attacks, Cobb AccessPort/DP
I'm a little over due for some maintenance on my 2002 WRX sedan.
In the manual it states "Drive belts". Does this include the timing belt? There is no mention of the timing belt in the maintenance schedule booklet.
If not, should I change the timing belt along with the other "drive belts"? My car is at 113K miles.
While I'm at it is it a good idea to change the tensioner and water pump?
Also, how much brake fluid and coolant does the car hold?
Thanks a bunch,
Chris
Thanks a bunch,
Chris
The schedule does indeed include the timing belt, however it is called the "camshaft drive belt". The belt is supposed to be replaced at 105K so you are overdue for this service.
Yes it is a good idea to replace the water pump and tensioner at the same time, to avoid problems with them later and because there is access to them while doing the belt.
Awesome...Thanks!
Location: Automotive racist capitol of the world, Detroit.
Car Info: 2000 impreza 2.5 rs
agreed except for the tensioner... if it spins free when you take every thing appart dont bother. I dont know on yours but mine was hydrolic and very expencive.
RE: Tensioner- that little hydraulic gizmo failed on my '02, causing the camshaft belt to come off the pulleys and 16 valves,etc., to be destroyed. It seems penny wise and pound foolish not to replace when everythings is opened. ps: my car is still under warranty, but it did take 21 days to get it back.
Heedz
03-15-2015 04:32 PM
wrx 03i
11-20-2012 05:58 PM
CCC
Engine and Drivetrain
02-02-2012 10:09 AM
dyndragon
02-02-2006 04:50 PM
