squeaking sound (when using A/C)
squeaking sound
Hi folks, got another rookie question,
when i turn on my AC there is a loud squeaking sound......it almost appears to happen when i turn with AC on .....it sounds like belts or something?
Most likely the belt that drives the A/C compressor. The clutch in the compressor engages when you turn the A/C on, this puts an almost instant load and drag on the belt, sometimes causing it to slip. That is likely the squealing sound that you hear. Check the tension on the belt. If you don't know how tight it's supposed to be, take it in for service. They should also be able to determine if the drive belt itself needs replacement. How many miles on the vehicle (belt)?
Car Info: 04 FXT 4EAT
I have the same thing. Sounds like a bird chirping under the hood. It does it consistantly every 2 minutes or so when the A/C is running. No other noises though when A/C is off. Car has 35,000 miles. 02 WRX.
it's the AC belt. my '02 WRX does it when i turn on the AC....it's a brief chirping sound that goes away after a second or two.
have them check the belt tension on your next service maintenance.
i had the same problem with my ac. i have 48k on mine. the belt is getting lose, all i did was tighten up the tensioner wheel and the squeek went away, bodda bing, it was gone, its easy to do.
7scooby
05-18-2005 11:21 AM
MRF582
03-03-2004 09:47 AM
impreza2002
02-06-2003 11:35 PM
Zoeb2s
12-03-2002 05:09 PM
