Replacing dashboard lights and whistling noise from driver's side external mirror
Car Info: 2003 Outback Wagon
Hi all-
Two questions:
I have an '03 outback wagon and a couple of dashboard lights are out, so at night I can't read parts of the instrument panel - like the speedometer and the fuel gauge. Is this a DIY fix, or should it be done at the dealer? If it's a DIY, any hints on how to access the lights?
Also, the external mirror on the driver's side whistles when I drive on the highway. I had the dealership look at it during a service check, and it fixed it temporarily, but it's back. Any idea how to fix it?
Thanks in advance-
Marybeth
'03 Outback Wagon, 55k
Two questions:
Thanks in advance-
Marybeth
To replace the bulbs the cluster has to be removed. This is not terribly difficult if you have tools and some mechanical ability, but if you don't a shop can do it easily.
As for the mirror, this is a common problem but the noise is usually not observed until very high speed (>100 MPH). If you're hearing it at lower speeds it could be something else. One thing you can check is to fold back the mirror and look for a sticker in the area where it folds, this has been reported as a source of the noise. If you find one remove it.
Car Info: The Dealer Specialist
vw_wrx
11-06-2005 02:16 PM
Rat
02-26-2004 03:49 PM
