Air Conditioning Noise
Car Info: 2002 Subaru WRX
I am the the owner of a 2002 Subaru WRX, purchased in September of 2001 with 48,800 miles on the odometer. I engaged my airconditioning today and was greeted by a horrendous squealing noise, like metal on metal. This noise could be toggled on and off by the using the air conditioning button at engine revolutions greater than 3,000 rpm so it is apparent that it is related to the air conditioning system itself. I did not have the time to lift the hood and do any trouble-shooting as I was running late for work.
I am curious if anyone else has experienced this noise and has any reccommendations as to it's repair. I refuse to have anything to do with the dealership in my location and I am actively searching for a Subaru certified mechanic in the Memphis area. Also, if anyone is familar with a good mechanic in the Memphis area and can make a reccommendation, it would be greatly appreciated. Thanks for your time and replies to this thread.
i have the same problem with my '02. i haven't had it checked, but it does sound like a belt tension issue...
i don't think it's worth freaking out over though. just have it checked. until then, i'll be sweating in my car. lol.
Ha, I have the same problem and was about to start a thread on it. It makes a lot of squealing when it is first warming up, but then it occurs for one sec every 45 sec or so. At that same point there appears to be a little bit of stuttering/power loss. Any ideas beyond "go get it checked out?"
BTW, mine doesn't occur when the car is cold or at certain RPM's. it occurs intermittently when my AC is turned on.
After reading some other threads, it definitely appears to be either a loose or worn out AC belt. I'll be getting it checked tomorrow.
edit - tightened the belt... problem solved.
If it is the a/c drive belt on an '03 car, that is considered normal wear and tear and not serviced under warranty. It is a specified replaceable item at the 60,000-mile service.
Impretzle
06-04-2005 06:13 PM
