STi shortblock, WRX heads, VF22 and so on..
Hey guys,
Its finally to the point in life where you go into the garage and say "WOAH, there is WAY too much Subaru crap in here!"... So here is what I got:
1) 2005 STi shortblock -
pulled due to cyl4 low compression (165,160,160,100psi), suspect rings due to leakdown. Complete shortblock, non-seperated. ASKING $300
2) 2004 WRX shortblock -
pulled due to a bearing failure. We drained the oil and it was bright gold, so a bearing has gone we suspect. Complete shortblock, non-seperated. ASKING $200
3) 2003 WRX heads -
theses are an extra set I have laying around. Can be either assembled or disassembled at your request. ASKING $350 both (comes with cams)
4) IHI VF22 turbo -
came off a GC8 JDM swap we ran (total miles are sub 50K), no turbine housing cracks, no shaft play (normal super small amount), has a small chip off the impellar inlet housing(atmo side, not pressure side). DOES NOT EFFECT ANYTHING. ASKING $250
5) 2002 WRX 5-speed manual gearbox (transmission) -
completely disassembled, 1st gear is completely gone and will require replacement (mainshaft and gear). Comes with cases/front diff/all gears /bearings/center diff/ and small other bits). ASKING $100
All parts are located in San Jose CA (Nor-Cal), you must come here.
See something overpriced, throw an offer.
_Richard
3) 2003 WRX heads -
4) IHI VF22 turbo -
_Richard
NorCalDC5
02-10-2010 10:52 AM
latinskllz
Subaru OEM Parts For Sale
01-13-2005 10:05 AM
02, 2004, 2011, block, compression, failure, heads, review, short, shortblock, sti, subaru, transmission, vf22, wrx
