Why not mod a 2.5RS rather than a WRX?
Old 03-04-2003 | 09:12 AM
FuJi K's Avatar
You can run all those turbo parts. You just have to worry about the pistons because the NA EJ25 motor runs at 10:1 compression ratio. Somwhere from 8.0:1 to 8.5:1 compression ratio pistons will make it engine a lot more reliable and less engine knock.
FuJi
Old 03-04-2003 | 11:31 AM
BlingBlingBlue's Avatar
Fuji K beat me to it. The biggest advantage of a factory turbo car for modding is a boost friendly motor. Lower compression ratio = more boost before detonation. You also get a DOHC motor with the WRX and I believe it's internals are stronger than the NA 2.5, although I'm not sure and could not tell you specifically what components have been reinforced...
The new factory 2.5 turbo which Subaru will put in the STi and others is going to be a great starting spot for insane power modifications...of course not by me. The novelty hasn't really worn off much from the 227 or so I've got now!
Old 03-05-2003 | 10:38 PM
Wingless Wonder's Avatar
Originally posted by Cycloexane
difine ej20?
EJ20 is the engine code for the 2.0 liter engine in the WRX. EJ25 is the 2.5 liter engine in some of the other Subaru models.
^ww^
"…axles of evil…" - George W. Bush
Old 03-06-2003 | 11:26 AM
IMO, EJ25 with after market turbo = really fun project
Stock EJ20t = really fun daily driver
Old 03-07-2003 | 02:40 PM
BeoWulf73's Avatar
Car Info: 2002 Impreza RS 2.5
i am
I have a 02 RS. And i have put in some $ and time to get my car to look, act, and be fast.
If you want a fast car with no work get a WXR
If you want a car that can be fast with not a lot of $ git a RS.
Old 03-07-2003 | 04:56 PM
240sxer's Avatar
Talking
i dont have the know how to put a turbo on, but i just cant afford a WRX so i am going to go with an RS and then save some money for the turbo kit... either that or a ej20 swap i have no idea yet.
ej20 swap for 7k (from what i heard) or a turbo kit for 4.5k the turbo rs would be in low 13's high 12's i assume (good driver)
even tho i wont be using this as a drag car, be nice to know how fast it is
Old 03-07-2003 | 05:04 PM
240sxer's Avatar
i was looking around at the UK scooby site (i think its uk) well on one of th scoobies i comes with cross/drilled/vented rotors. i read somewhere that its mainly for looks and that it doesnt really benifit all that much and in some cases arent as good as solid rotors. is this true? i think it came with the RB5
LifePlaza
09-12-2008 01:12 PM
Travis10
11-14-2005 03:18 AM
Kostamojen
10-15-2005 08:23 PM
godfather2112
04-05-2004 09:57 AM
Quick Reply: Why not mod a 2.5RS rather than a WRX?
