Trunk popping noise?
Popping noise only happens when I pull into a driveway and the rear tires go over the bump. Car has to be going downhill then up for the noise to happen. I can hit a speedbump at any speed and it wont make the noise. I can go over the bumpiest road and no noise. Only when going into a driveway. Stock suspension except for rear sway bar and end links.. any ideas???
I hapened to mine too...
From the factory EVERY bolt is finger tight on the whole dam car.
I would bet that the bracket that mounts between the frame and the rubber/urathane bushing on your rear sway bar is loose. This bracket has 2 screws going into the frame (if thats what ya call it on a unibody car). There is a bracket at both ends of the sway bar.
![Question](https://www.i-club.com/forums/images/icons/icon5.gif)
I know the popping you're talking about. I've got an 03, and it mainly does it when I'm backing out of my driveway at a slow speed. I've noticed that it will mainly do it if there is a difference in elevation (like a driveway).
I took it to my dealer and, of course, it wouldn't do it at all! They told me that I still had plenty of time left on the warrenty and to bring it back when it gets worse.
I don't think it's a big deal, but it drives me crazy.
