Remote start help!!
Old 01-19-2009 | 07:36 PM
blackbullet03's Avatar
Car Info: Subaru WRX Impreza
Remote start help!!
Hey guys, i'm installing a Viper 5900 remote start alarm system. Everything is working great, but one thing...
When I press the remote start button on the remote, the car cranks but it won't start. I don't know what the problem is. I re-checked all the wires and everything, but I just don't know what it is.
If anyone is familiar with this please help, any help is appreciated. Thanks. I'll be checking on my laptop frequently, i'm working on the alarm right now.
Thanks guys.
Old 01-19-2009 | 09:55 PM
DemonPossessed's Avatar
Car Info: 05 wrx
is the tach wire connected properly so that it knows when the car starts?
did you bypass the clutch?
Its been years since i installed my remote start.... uggh sorry
Old 01-26-2009 | 01:51 PM
Jin's Avatar
Jin
Car Info: 05 CGM STi to be converted to RS
what year is your car? sti?
as far as i know, non sti's dont have chipped key, sti's do.
did you install key bypass or the cheap way, put your extra key in the steering column, close to the key cylinder as possible, i cut my key part out and just left the chip part, other people have taken the whole key apart and just put the chip (maybe 5mmx5mm).
if not, make sure your tach is programmed and is on the correct tach wire which can be tested with a multimeter, put it on AC and as the rev climes, the voltage will clime too.
or you can put your alarm into voltage sense mode or crank time instead of tach to make it easier.
hope it works out for you.
domchao
05-24-2010 01:15 PM
Silentsamurai
10-18-2006 03:03 PM
tartay
06-18-2003 11:14 AM
tartay
05-25-2003 10:13 AM
nvsprelude
03-25-2003 06:05 PM
Quick Reply: Remote start help!!
