proper oil pressure?
Old 08-09-2007 | 09:21 AM
jsubby's Avatar
Car Info: 1996 Subaru WRX V-Limited
sup everybody,
What would be a proper oil pressure reading (PSI):
When first stating the car (WRX) in the morning?
When driving hard under boost?
When in idle?
This might be a very dumb question but anyway:
What would cause your oil pressure to be too low or high?
Thanks in advance
Much appreciated
j
Old 08-10-2007 | 01:30 PM
Oogie's Avatar
Car Info: 99 M3
Your oil pressure depends largely on your engine operating temp and the viscosity of the oil used.
Assuming a 212 F operating oil temperature of the engine on the highway, a 5w30 and 5w50 will have a different viscosity index. Remember that more pressure doesn't mean more lubrication. Imagine sucking honey through a straw compared to water.
So therefore oil pressure driving hard under boost, idle, and starting the car all depends on other factors. Just remember that the outside ambient has no significant impact of the engine oil operating temperature once the vehicle is moving and enough air is flowing through the engine bay. Synthetic oils are not as volatile in terms of composition changes in comparison to conventional dino oils due to outside ambient temperature
If your car overheats in these conditions then something is wrong with your cooling system. The analogy here is that a pot of water doesn't keep getting hotter and hotter if you're boiling it at one constant temperature, it will peak and stay there. The airflow going through your vehicle and the cooling system provide the temperature stability for your engine.
Read this:
http://63.240.161.99/motoroil/index.html
Old 08-10-2007 | 02:07 PM
jsubby's Avatar
Thanks alot man ....
very helpful
appreciate it
Subadubaru
02-06-2013 02:20 PM
06ezSTI
04-22-2008 08:00 PM
suby_dude
02-12-2008 01:28 PM
JackHCChen
11-12-2005 09:50 PM
turbo_j
03-16-2003 02:49 PM
Quick Reply: proper oil pressure?
