Oil filter torque?
You should only hand tighten it. It usually says on the filter but something like 3/4 of a turn after it's snug. If you tighten it too much you risk a leak. It's always best to start the car twice after you change the oil and the second time while the car is running get out and look to check for leaks. If you tighten it too much you can squish the gasket get a leak.
here is a guide:
http://www.scoobymods.com/forums/sho...=&threadid=171
here is a guide:
Originally posted by Peaty
[B]You should only hand tighten it. It usually says on the filter but something like 3/4 of a turn after it's snug. If you tighten it too much you risk a leak.
It's usually one hand to put it on and two to get it off. If it's done right you really shouldn't need a filter wrench to get it off. I always seem to need one though just to get it started.
fd777
06-12-2010 09:05 PM
iLoqin
06-06-2010 10:47 AM
nation
04-17-2009 01:16 AM
JackHCChen
11-12-2005 09:50 PM
wrxout
10-26-2005 03:13 PM
