mirror vibrating.....
I have the mirror in my WRX with the compass. and when i have my stereo turned up (2 12inch subs in the trunk) The mirror makes this enoying rattling. Any idea on how to fix this with out holding the mirror or turning down the volume???
You can buy a little O-ring, cut it, and squeeze in there, I did that to a few things on my car (not a WRX sadly) or you could use black rubber based caulk. The best way if possible would be to support it from the back if you can get in there.
im not exactly sure where you to put anything back there. I think its the actual mirror part itself not where it connects to the windsheild.....
Ill check again to make sure though
it just seems like thats the only thing that is making noise...inside the car anyways.
yanimaya
12-13-2008 01:53 PM
