hood scoop screen help please
Old 08-19-2003 | 02:36 PM
escaflowne's Avatar
Car Info: 2004 Black WRX wagon
hey. it's about time i got a screen. i hate cleaning out bugs and leaves.
anyways... which brand do you guys recommend? fit/price/"look".
thanks.
i hope it doesn't make my car look crappy... i don't like the grill look... prolly just paint it black so i can't see it.
Old 08-19-2003 | 04:52 PM
bone324's Avatar
Car Info: '02 WRX WRB
I recommend the Home Depot brand. I paid like $5 for the screen and another $5 for some tin snips. I cut it to size and attached it to the underside of the scoop. No bugs, no leaves. Painted black I can't even see it.
Old 08-19-2003 | 07:43 PM
awns729's Avatar
Car Info: want a WRX
www.vividracing.com may be of some help...or the hope depot thing is a really cool idea
Old 08-19-2003 | 07:47 PM
ScoobyBoy's Avatar
just go to home depot and make it yourself. 5 bucks and you can make as much as you want. i over lapped mine to have a finer grill.
oh its going to be even worse when the bugs get past the grill. you'll have to take off the grill and take them out. even worse when the bugs split in half when they hit the grill.
Old 08-19-2003 | 08:02 PM
awns729's Avatar
try putting a grill over the intercooler also....it could work, right?
Old 08-20-2003 | 06:42 AM
ScoobyBoy's Avatar
no doubt. i actually misread or something and thought he was talking about an intercooler grill. hell go to home depot spend 5bucks on chicken wire mesh, and make one for the scoop and intercooler.
Old 08-20-2003 | 07:38 AM
Trvlr5's Avatar
Car Info: 2003 WRX in World Rally Blue
Sccop grill
The ones being sold on the Internet are made from a heavier duty screen than chicken wire - but that would work too.
If you get a piece of screen ( I think fireplace screen material would work ) about 2 feet wide and six inches high that will be more than enough to cover the opening. 6 small black zip ties, the screen material, and some tin snips and you're in business.
Heck, if you've got some wire cutters you could get by without the tin snips. It'd take a lot longer is all.
Old 08-22-2003 | 04:57 PM
rhk118's Avatar
Car Info: '03 Black Sedan
You can get aluminum gutter guard from Home Depot for pretty cheap. The mesh is fine enough to stop even small rocks...Easy to attach to the top of the intercooler by just cutting a piece to size and then bend it over on the left and right of the intercooler which should hold it in place (zip-ties may work as well). I've seen posts where people also put it at the base of the scoop and even in the opening of the scoop. If you use 3 layers though I think you'll interrupt the laminar flow of air too much and decrease cooling efficiency...One layer is better than none!
Old 08-22-2003 | 07:54 PM
awns729's Avatar
maybe get the STi hoodscoop while ur at it
Old 08-22-2003 | 08:01 PM
rhk118's Avatar
Great Idea!
Old 08-22-2003 | 08:25 PM
bone324's Avatar
I considered the gutter guard, but it looked too narrow to cover the entire IC. But just down the aisle I found some general purpose metal screen. It's heavier than chicken wire and it has larger holes than window screen. I overlapped two pieces of the screen to make the holes even smaller and painted the whole thing with high-temp flat black engine enamel. Then I removed the stock hood scoop air diverter attached to the underside of the scoop and put the whole screen in between the rubber seal and the diverter. Then I replaced the diverter. For my friend's WRX we just decided to overlap the screen, paint it black, and set it on top of the IC fins. It works just as well and is easier to maintain that way. The problem with bending the screen over the outside edges of the IC is that the rubber seal that forces the air into the IC actually drops down below the edges and sets on the fins. It would be a mistake to remove that seal and allow hot engine air to flow through the IC fins. Either way, it's way cheaper than anything from Vivid or any other vendor and works just as well.
scenic
07-06-2010 01:21 PM
tamko
12-07-2008 12:55 AM
HRMax
12-12-2004 06:03 PM
Impreza_Power
08-12-2004 02:05 PM
laurex
08-18-2003 04:33 PM
Quick Reply: hood scoop screen help please
