Front end problem.
Old 03-11-2011 | 03:48 PM
wakeskatemike's Avatar
Car Info: 2003 WRX
Front end problem.
So my brothers friend has a 06 wrx and she is having a crazy wable out of the front driver side wheel. She says when she is going about 70 on the highway and starts to brake, the drive front wheel starts wableing. I haunt had a chance to look at it just seeing if anyone had a similar problem. I was thinking maybe ball joints??
She said she too it to garage one in San Jose and the said it could be ball joints or the control arm.
What would be wrong with the control arm..? The bushings?
Any help would be great.
Thanks.
Mike
Old 03-11-2011 | 03:50 PM
johndabrit's Avatar
Da Brit.
could be something as simple as warped rotor, which can feel like a wobble. It may be a wheel bearing but if its that far out, it should make a whirring noise with the wobble. good god i'm drunk.
Old 03-11-2011 | 10:05 PM
03wrxbugeye's Avatar
Car Info: 03 wrb wrx
it could be bent like she hit something or as little as unbalanced wheels or the wheel weights came off from normal driving...but it should be covered under warranty still so check with the dealer....
Old 03-16-2011 | 08:37 PM
Crafty Slug's Avatar
Car Info: 1991 Mitsubishi Galant VR-4
without seeing the car, warped rotors.
Old 04-17-2011 | 11:31 AM
peterislazy's Avatar
Car Info: 03 WRX WRB Sedan
with my eyes close, warped rotors. In most cases, if it happens during braking, then it's likely the rotors.
younger619
04-28-2014 12:55 PM
FL4T
12-23-2013 11:01 AM
con10der_8
07-26-2010 01:23 PM
Subadubaru
05-03-2009 07:03 AM
illogical
Wanted
02-15-2006 09:32 AM
Quick Reply: Front end problem.
