Dominate the outdoor maintenance and agricultural world with a Subaru engine
Use Subaru engine in a log splitter or chipper/shredder FTW!
click pic for spec sheet
All Subaru Robin Engines Have One Thing in Common— Quality!
All models offer heavy-duty features including aluminum alloy blocks with cast iron cylinder liner, electronic ignition with automatic timing adjustment, dual ball bearing supported crankshaft, automatic decompression system, and splash type lubrication. Optional features available on selected models.
EXTREME Advanced Technology & Engineering—
Based on the Subaru WRX World Rally champion car’s boxer engine.
EX27 STANDARD FEATURES AND SPECS
Class: Overhead Camshaft
Horizontal Cylinders: 1
Displacement cc: 265
Cycles: 4
Fuel: Gasoline
Max HP/RPM: 9.0/4000
Continuous HP/RPM: 7.0/3600
Max Torque ftlbs/RPM: 13.74/2500
Bore x Stroke mm: 75 x 60
Compression Ratio: 8.3:1
Fuel Capacity US Gal: 1.59
Cycles: 4
Fuel: Gasoline
Kire
12-05-2009 11:53 AM
FoToHo
07-07-2004 10:40 AM
FaLeX
11-27-2002 09:07 AM
