car wont start! please help me get to work
Car Info: MY00 BRP GC
hey guys my car will not start.
car-2000 2.5rs auto
i went to go start my car this morning and whatever i tried it just would not start. i turn the key all the way and there is no noise at all. absolutely no sound from starter or anything at all. all the lights work and battery is confirmed to be good.no CEL. just Nothing! so i am stumped at this point.
my ideas are
*brake sensor (or some other sensor)
*starter motor (how would i go about testing this?) i have a voltage meter but not sure what wires to test
*ECU
if anyone could please lend me a hand that would be greatly appreciated. thank you
car-2000 2.5rs auto
my ideas are
*ECU
Car Info: 2010 Forester
Sounds like the battery connections are loose. Your lights can work off the voltage of a slight connection, but your starter cannot draw enough. Check the connections and make sure they're nice and tight with no play.
Car Info: 12Teens crazy 4 me
Could be a battery that has lived its life, and cannot give the correct amperage to turn the engine over.
The leads on the alternator could be corroded.
Alternator fuse? lol idk if there is such thing.
nothing to do with battery. it works perfectly. all the connectors are clean. i just took out my starter since i checked almost everything. anyway to check if the starter is bad since its out already?
Try swap out the battery, sounds like there isnt enough current to power on the system. Or if you have a Digital Multi Meter, try to measure the voltage. If its below 12V, time to get a new battery.
tested the starter and didnt work for me but took it to kragen and it worked for them.voltage meter for battery ready 12-13 volts.will try starting it in nuetral after i put the starter back in
then your battery is bad (doesnt provide the amperage for a starter, just enough for headlights which use less than 10~15amps)
OK guys after a full week of struggle and a new starter it still didn't start. buttttt I FIGURED THIS STUPID THING OUT! the black cable that connects from the ignition to the starter solenoid wasn't contacting. all i did was clean it up and plugged it back in it started right up. its funny because i was just about to call a tow truck to pic her up and take it to the shop. thank god i figured this thing out.
muskatomas101
12-02-2007 04:30 PM
jeanna0221
05-01-2006 06:58 AM
krillz
07-02-2003 04:37 AM
DDImpreza
05-28-2003 03:10 PM
