Car vibrating at 60+mph
Hi guys,
I got TEIN basics and set of Work Emotion CR 17x8 about 3 months ago. I had vibrating issue on 60+ mph after the install and I did the following thing:
- new lug nuts(grilock spline drive), was using stock one
- was told I have a slightly bent wheel, counter balanced
- did alignment at AI( OE spec) after coilovers are set on height
- new tires
The vibrating problem got a bit better and still bugs me. My car still vibrating at 60+ mph. I'm not sure what else to look for. I got the wheels from friend and the lug nuts he gave me is a bit larger than the grilock one i purchased. Would this cause such problem?
Thanks for the help!
- new tires
Originally Posted by excel
what year is your car? it could be other things than what you said
Originally Posted by mudman
It could be as simple as the bent rim, counter-balancing a bent rim is not always a foolproof solution.
yanimaya
12-13-2008 01:53 PM
