Can someone help me convert 750cc injectors into lb/h
I don't know if you can convert cc to lb/hr. Seems like you'd need some sort of time information on both sides of the equation. As in, you could convert cc/hr to lb/hr or cc/min to lb/hr
Google says: To convert cc/min into lb/hr, divide cc/min by 10.5.
Car Info: 2002 Impreza WRX Sedan
Hope this helps.
the saturn guys numbers don't make sense.
that 71.4lb/hr is slightly off
the density of gasoline is 672.8 kg/m^3
mass flow rate = density * volumtric flow rate
750 cm^3/min = 0.045 m^3/hr
mass flow rate = 672.8 kg/m^3 * 0.045 m^3/hr
mass flow rate = 30.276 kg/hr
30.276 kg/hr = 66.747 lbs/hr
so the mass flow rate of 750cc injectors is 66.747 lbs/hr
Origami posted by Imprezer
Can someone help me convert 750cc injectors into lb/hr?
You know I'm probably going to move this thread...
Jani Raxter
08-11-2012 12:25 AM
Paradox
13
01-03-2008 10:57 PM
