A/C problems, help!!
i didnt know where to post this so i posted it here...
my A/C donesnt work on my 2003 RS, the button lights up, but the compressor itself doesnt turn on
this is the first time i tried to turn the A/C on since i bought the car, so i just guess it never worked
does anyone have any ideas on how to fix it? i checked the fuse and its fine
thanks
thanks
Car Info: 2002 wrx wagon, wrb
I had the same problem in my WRX, i took it in to the dealership, and it turned out to be a hose that was kinked, and loose. I don't know if this helps, but check the hoses for kinks or to see if they are loose.
It is probably low on refrigerant (yes this can happen on new cars), either due to a leak or an insufficient charge from new. There is a low-pressure cutout switch in the system that protects the compressor by preventing it from engaging if the system pressure is too low. Your car is still under warranty (unless you've managed to drive more than 36K on an '03) so have the dealer fix it.
Oh, there is one other possibility that would not be covered under warranty. Because the condensor is located in an exposed place (in front of the radiator, in the bumper opening), it is possible for a rock or other road hazard to impact and puncture it. Hopefully this is not what happened.
thanks for the posts, im gonna check it out in the morning...
the thing is when i hit the AC button, the compresor doesnt seem to come on (like in most cars, u hit the AC button and u can notice the RPM's go up a little bit, and u can kinda just hear it)
it best be covered under warrenty... or else ill have to run out on the bill :-p
grex767
05-27-2006 10:37 AM
cal_choi
09-15-2003 10:06 PM
Zoeb2s
02-27-2003 08:11 PM
