Boost question
Old 04-01-2008 | 11:14 PM
DjTragik951's Avatar
Car Info: Subaru WRX
Boost question
problem fixed
Old 04-01-2008 | 11:17 PM
03_Impreza_Al's Avatar
Which BCS are you using? Everything installed correctly? Start logging and see what you need to adjust.
Oh which map is this?
Old 04-01-2008 | 11:29 PM
its the stock boost controller.i dont know what map it is all i know is that its for my set up .i bought the map from a tuner at nasioc and had a friend flash it.
Old 04-01-2008 | 11:30 PM
mmhmm... Might want to do more research before jumping into Open Source tuning. GL with that.
Old 04-02-2008 | 11:29 PM
bump i refrased my question
Old 04-02-2008 | 11:31 PM
You need to log the car and see what it is actually hitting...
Old 04-03-2008 | 12:09 AM
thats what i wanted to do but the dude who reflashed my car sold his cable and nolonger deeals with Opensource tuning
Old 04-03-2008 | 12:38 PM
ok i connected the green connectors uonder the driverside dash and checked to see if the stock BC did anything but it dosent . is it suppesed to blow ir suck air? or make a cliking sound?
Old 04-03-2008 | 10:17 PM
Problem solved!! I installed an AEM tru-boost controller/gauge in one. and car runs strong. and i can boost it up to 18 lbs. but im doing 17 just to be safe.
yzercyber
08-12-2005 03:42 PM
Astacun1
06-28-2003 03:12 PM
mattr762
04-18-2003 09:12 AM
ShokWaveRider
02-21-2003 06:14 AM
XwrxX
12-17-2002 07:14 AM
Quick Reply: Boost question
