Which speakers to put in the front door of my 02 wrx?
Alright.
Now, one of these is to go in the rear deck (i have an 02 wrx and custom installed speakers there) and one is going in the front doors. I have a kenwood 600.2 to power the speakers in the rear deck, i could also run power to the front speakers. In the rear doors I have kicker k525 speakers, and for bass i have a diamond m6 in a slot ported box.
Saying all that, which would you guys put in the front doors, the eclipses or the alpines?
I have 6.5" eclipse sp8962 coax speakers up front, these speakers are ...
Continuous Power Handling: 50W
Music Power Handling: 100W
Frequency Response: 70Hz-20kHz
Concentrically Mounted, Efficiency-Matched Components
Butyl Rubber Surround
Mica-Filled Polypropylene Cone (MFP)
Kapton Voice Coil Former
3/4Ferro-Fluid Cooled Neodymium Silk Dome Tweeter
Model-Specific Computer-Optimized Outboard Crossover
Tweeter Protection Circuit
Alminum Power Handling Tweeter Post
Mounting Depth: 2-3/8
I also have 6.5" alpine type r APN SPR174A
Speaker Size 6-1/2"
Speaker Type 2-Way
Woofer Cone Material Hybrid Aluminum Polypropylene
Woofer Surround Material Rubber
Tweeter Design Silk Dome
Directional Tweeter Yes
Midrange Design N/A
Sensitivity (dB) 91
Frequency Response (Hz) 35Hz-35kHz
Recommended Amp Wattage Range 5-60
Peak Power Handling (Watts) 160
Speaker Size 6-1/2"
Speaker Type 2-Way
Midrange Design N/A
Sensitivity (dB) 91
Urglegrew
Subaru OEM Parts For Sale
09-05-2010 03:38 PM
stubz203
03-19-2007 07:31 PM
Lagwagon56
03-03-2004 06:14 AM
Steppin Razor
01-29-2003 03:56 AM
