Remote wire on 6 disc head unit?
Old 06-08-2004 | 04:39 PM
VRWRX's Avatar
Car Info: 2005 CGM WRX Wagon
Here's a wiring diagram of the HU for an 02. It should be the same as an 04:
http://www.ravensblade-impreza.com/m.../radiowrx.html
I think you can use either pin 10 or 14.
Old 06-09-2004 | 08:22 PM
Mulder's Avatar
Car Info: 02 WRX WRB
The switched power from the HU is for the power antenna so that is why it only comes on with the radio. There is no other source of switched power that goes on and off with the HU. If you plan on keeping the stock HU the only alternative is to use a source of ignition switched power as you are considering (ACC power). The downside of this method is the amp and sub will turn on anytime the ignition is on, even when the HU is off. Aside from them drawing power all the time there may also be some noise from the speakers.
I'd suggest replacing the HU with an aftermarket unit which will have both preamp outs and the proper switched power, unless you are married to the OEM one for some reason. The sound will be a lot better too.
Old 06-09-2004 | 09:51 PM
cyyeo's Avatar
Originally Posted by MoodyWRX
I have a 2004 WRX with the stock 6 disc in-dash head unit. I am adding an amp and a sub to the system, but I am having trouble locating a remote/accessory wire from the head unit. does anyone know if it even has one? If not, any ideas on an alternative solution. Everything else is set up after having to use a LOC since the head unit doesn't have a pre-amp rca output. Any help would be much appreciated!
PAC LOC are awesome.
I installed one in my subaru and have no complains about it.
It provides a remote wire from the unit itself.
Check out the link below.
http://www.electronixwarehouse.com/c...s/pac-oem2.htm
Charlie Yeo
zunus
03-17-2004 12:52 PM
BlueSti389
11-19-2003 10:54 PM
smjkxsnoopy
09-08-2003 10:21 PM
rallyryan
Subaru OEM Parts For Sale
05-22-2003 09:00 PM
4XREX
01-07-2003 10:27 PM
Quick Reply: Remote wire on 6 disc head unit?
