Help! Stereo Head Unit won't turn on after Oil Change
Old 12-20-2004 | 04:29 PM
Cardiff Giant's Avatar
Car Info: 2004 Impreza Outback Sport
there should be a legend on the inside of the fuse panel that says which one is for the HU.
Old 12-21-2004 | 06:53 AM
faeker's Avatar
Car Info: 2003 WRX
check to see if the accessories work also...ie cig. lighter, interior lights. also, did you check the fuses under the hood, or under the dash? i don't think it would be the ground that's causing the shox you keep getting. it could just be dry weather.
Old 12-22-2004 | 01:12 AM
ldivinag's Avatar
03.23.67 - 06.14.13
first, say what year/model car you have.
then say what radio it is, oem or aftermarket, etc...
finally, you dont know the time i tore apart my truck thinking it was a fusible link buried in the dash why something wasnt working.
turns out the fused i replaced a blown one, looked OKAY but when i tested it with a voltmeter, it was dead....
SlickmisterN
03-15-2019 05:06 PM
i<3dirt
10-20-2014 11:26 AM
yzercyber
03-02-2008 07:02 PM
Heavy Dan
10-24-2004 12:06 PM
