deck cutting power too fast? sub thump
Hey everyone,
I just got my Alpine CDE-121 deck installed with 4 gauge wires with an Infinity Basslink powered sub. I noticed that when I turn off the deck or the car the sub makes one pop/thump sound. The installer said that it sounds like that the deck is cutting the power too fast causing the thump/pop sound that the sub makes. I talked to crutchfield customer support and they told me that it may be faulty RCA or ground wire..in fact, the guy said his best bet is the ground wire. I relocated the ground wire 2-3 times and the sound is still there. anyone ever experience this?
Thanks!
Thanks!
Originally Posted by jdblock
Have you sanded away any paint where you are grounding it? You can't just use a bolt as paint and primer are usually in the threads where the bolt goes.
=(( im scared that my sub might go out before I even resolve this!
If in doubt, FLAT OUT
When they installed it, did they use "signal sensing" turn on or remote turn on? I don't remember mine ever thumping like that, but it is a result of the delayed turn on/off. The ground has nothing to do with this.
I had one and I don't remember having thump with mine, but that while ago, so I don't remember if it has one or the other or both, but I think the signal sensing might me more likely to cause thump, while a wired remote turn on would turn the sub on and off directly. Might ask the person who did it how it was setup.
Found this, so I guess you need to find out if it was speaker level or RCA connected, and yes it has a remote turn on input (says Basslink X, but I think it is the same setup for all of them):
BassLink X can accept up to four channels of input to provide non-fading bass either from line-level signals through four RCA jacks or from high-level signals through a pair of Molex connectors. Infinity supplies two 6-meter color-coded wiring harnesses for high-level signals, allowing BassLink X to be easily connected to OEM systems. If using the speaker-level inputs, an audio-sense circuit will turn on the amplifier whenever a signal is present. If the RCAs are used, a 12-volt remote turn-on lead is required. The system has barrier strip connections for power, ground and the remote turn-on.
Car Info: bugeye WAR wagon
sanded two different location and still negative, thump is still there.
weird thing happened, i turned the gain down from halfway to zero and there was no thump. I increased it to 1/4 turn and now there's a thump when i turn it on and just a weak thump when i turn it off.
ziggydikface
08-09-2004 12:07 PM
RussB
04-10-2004 04:23 AM
