Big problems- Stereo install. Help...
Old 04-08-2003 | 10:43 AM
jasno999's Avatar
Car Info: Blaze yellow WRX 2002
Big problems- Stereo install. Please Help me...
Well a year ago I installed a small sub with built in amp. In order to get it to work I converted my outputs from the factory head unit to RCA cables and ran them back to the sub. Worked.
Then I decided to add an amp so I could do my front and rear speakers. I did the rears about 8 months ago. And it was good. But I was holding off on the front until I had time and material and spacers to get the job done.
Well one problem I noticed was this whining noise when I first hooked the amp up. Sounds like it is coming from the hood so I am guessing it is the alternator. It is this strange whin that is affected by RPM. And now I hooked up one front speaker to the amp and the noisse got worse.
I am scared of what it could be. Any ideas? Any suggestions?
Also how did you guys mount the crossovers in the door and the tweeters?
Old 04-09-2003 | 05:25 AM
jasno999's Avatar
I am goign to go out and purchase 2 ground loop isolators and I will try to find a better ground for my amps. Got any good places in the trunk?
Old 04-14-2003 | 05:44 AM
jasno999's Avatar
The ground loop isolators did not help. They actually made it worse. Not sure why. I thought they would help.
My last idea is to take the back seat out and ground the amps to the seat belt bolt. That should be my best ground.
Old 04-14-2003 | 11:41 AM
jasno999's Avatar
I have power on left side of the car and RCAs on the right side.
The only place they come close is at the amp but that is eneviatable really.
I don't see why I need a bigger ground cable. I think the same size cable should be fine. I am runniing 4ga. so I think that is ok.
I noticed today that if I turn the radio off I get the sound. But if I pull the RCAs out thne the noise goes away. A friend said that my problem probably lies in the RCAs because if it was a power or grounding problem then I would still get the noise even if the RCAs were pulled out. Does anybody agree or dissagree with this?
Old 04-14-2003 | 06:00 PM
jasno999's Avatar
I am not sure. I thought they were shielded but now I don't know. They are not the highestqulaity RCA cables.
Tonight I went out and changed my grounds and wired a ground from the head unit to the ground in the read. And the noise is still there.
Yes there is a noise even when the car idles. Even with the radio off. But if I pull the rcas with the car running then the noise goes away. So my last thing to do is try new RCAs and run them outside the car to see if they work. I know there are some other noise filter devices like GLI with noise filter- I purchased GLI and they made it worse so I am scared to get more stuff. That and I saw a RF interference reducer that was cheep.
I jsut don't know what to do next. This is killing me.
Old 04-15-2003 | 05:41 AM
jasno999's Avatar
Well here is the deal. I started small with just the sub. And I did not want to go to extream lengths. But as time went by I decided to do more and more. But the one thing that I really liked was the 6 in dash CD changer and I wanted to keep it a double DIN cause that just looked better to me. So that is why I kept the factory head unit.
I have a lanzar amp and Infinity Sub. The small sub that comes in its own enclosure. Actually sounds great.
I am not made out of money and I can nto just go buy another amp and sub and hook it all up. So that is crazy for you to say. I need to find a way to make what I have work. I appreciate constructive ideas and help from people on the board. And most people really try to help. So thank you for the suggestions but I need help making what I have work.
