Introducing the Defi 52mm Red Racer Gauges!!!!
Exclusive gauges for the USA which are derived from quick-responsive and high-accurate Defi analog gauges. Features include:
* Stepping motor "STEP MASTER VS-2" provides smooth operation
* Ignition ON initiates self-luminescence gauge
* Red illumination using high-brightness LEDs
* Full 270 degrees sweep dial provides ultimate visibility
* A mounting bracket and instrument case is provided with the product
* The red triangle of the regular position bezel can be used as a warning indicator
* Does not require the Defi-Link Control Unit for use (Blue Racer Gauge cannot be connected to the Defi-Link System)
Self-diagnostics function monitors both sensor disconnection and short-circuiting during startup.
a) Sensor disconnection check:
This function reports any in-proper connections, broken or disconnected sensor or sensor wire. The pointer will wave between 250 and 260 degrees.
b) Short-circuiting check:
This function indicates any short circuit on the sensor or sensor wire.
The pointer will wave between 10 and 20 degrees.
Defi Red Racer Boost Gauge Imperial [DEF DF06502] - MSRP: $192, 2008 Special Introductory Offer - $165 + tax
Defi Red Racer E.G.T Gauge Imperial [DEF DF06802] - MSRP: $235, 2008 Special Introductory Offer - $210 + tax
Defi Red Racer Pressure Gauge Imperial [DEF DF06602] - MSRP: $235, 2008 Special Introductory Offer - $210 + tax
Defi Red Racer Temp. Gauge Imperial [DDEF DF06702] - MSRP: $160, 2008 Special Introductory Offer - $144 + tax
Defi Red Racer Voltage Gauge Imperial [DEF DF07005] - MSRP: $120, 2008 Special Introductory Offer - $110 + tax
In stock and ready to for install or pick up!
No need for control unit!!
Each gauge includes a Defi Single gauge pod.
Also, Receive an "A Bathing APE" T-shirt For FREE w/ purchase of Defi Red Racer 3 gauge combo today!!!
Boost, EGT, Pressure, and Temp are in stock ready for pickup!
Blue and White Racer Gauges also available!
-Rob
510-226-8822
GST Motorsports
Exterior / Interior Lighting
09-09-2008 12:04 PM
Speed Element
03-24-2008 01:33 PM
201Motorsports
17
07-27-2007 05:55 AM
GGBGuy
12-05-2006 07:12 AM
SOOB
08-30-2006 03:08 PM
