Raw gas smell in the car 05 wrx wag
Old 08-22-2012 | 01:44 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
After leaving the gym yesterday I could not help but smell raw gas coming out of my vents. I figured its not a big deal as it'll eventually go away. I turned up the fan and i continously smelled it. eventually it got me sorta light headed and i just left the windows open and turned off the fan. I got home opened my open and i can seem to find any leaks anywhere.. I found that it smelled like fuel in around the motor as well.. anyone have this problem or have a fix to this?
2005 WRX Wag
68k miles
No exhaust mods but axle back. This is installed awhile ago.
Old 08-22-2012 | 01:48 PM
tourexy's Avatar
Car Info: 02 PSM Impreza WRX
Had similar issues but it wasnt coming from the vents. Smelt it on the driver side when windows are down and turned out to be some really old cracked fuel lines (02 WRX). Hope it helps
Old 08-22-2012 | 01:51 PM
TheLegend's Avatar
Enjoys his Ponies
Car Info: 2014 Mustang GT Premium 5.0
Stop farting as much
Old 08-22-2012 | 02:23 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
cracked fuel line? man.. wouldn't it leak?
and the legend.. trust me bro..i've been trying. actually smells better than the raw fuel.
Old 08-22-2012 | 03:31 PM
DSav408's Avatar
Car Info: 07 UGM FXT
05's had a fuel line recall? I had mine replaced at the dealership for free. Not sure if that is your issue or not. But worth a shot if it hasn't already been fixed.
Old 08-22-2012 | 03:37 PM
RicoNX's Avatar
Car Info: Subaru 2003 WRX
This is something that happens to a lot of the WRX's, its a faulty fuel line under the manifold. normally this will only affect the 02-04 models i believe, not sure if the 05 too, but either way, Subaru has an extended warranty for this problem , so all you have to do is find a subaru dealership near you call and let them know whats going on and make an appointment , should be at no cost to you.
Old 08-22-2012 | 03:40 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
05s aren't affected in regards to the recall.
most likely it still is a cracked fuel line or bad o-ring at the injector and won't be warrantied. have someone track the leak down, would not suggest driving.
Old 08-22-2012 | 03:46 PM
RicoNX's Avatar
yeah just checked and the 05 models already had the new fuel line set up, Good luck with this dude, be sure to check for any little puddles if thats the case i'd stop driving it .
Old 08-22-2012 | 03:47 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
appreciate the input guys. as for driving it.. i can barely drive it without feeling nauseated. it just happened and wasn't like i did anything to crack it. Hopefully there is a recall on it. hate forking over cash when i didn't do anything to cause the problem.
Old 08-22-2012 | 03:57 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
there's no recall.
check under the turbo side coolant reservoir, under the intake manifold should be a fuel line with a clamp towards the back of the two runners, either could be leaking, that's the most likely culprit.
i don't have direct experience, i'd recommend you pm tofuman to take a look.
here are what the lines and connectors look like
Old 08-22-2012 | 04:09 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
hopefully that should be it...thanks again! imma go scope it out when i get home from work. appreciate the help.
Old 08-22-2012 | 09:58 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
was only able to tighten one of the screws hidden between the intake manifold on the turbo coolant reservoir side. the other one was upside down. anyways just found any of the screw clips along the fuel line and tightened them.
turned on the car and no more gas smell almost immediately...so thanks for all the help guys. I couldn't have done it with out yall.
Old 08-22-2012 | 10:56 PM
thejordan's Avatar
Retired War Hero
Car Info: .gifs
keep monitoring it, there still may be cracks in the lines, stuff usually doesn't just come loose. i'd suggest do a cold start, turn it off real quick and check for gas. if you do it warm it could just evaporate and smell.
Old 08-22-2012 | 11:29 PM
rupees88's Avatar
Moist IT Outsourcing Services
Car Info: Mahindra Tractor
this.
Old 08-22-2012 | 11:56 PM
mistaanime's Avatar
Loves the Anime
Car Info: STWODUCES
thats what i figured. but when I found the screw clamp in between the intake manifold i turned it easily about 6 turns. Anyways, of course i 'll keep monitoring it. no gas leaks that is for sure. thanks again
Quick Reply: Raw gas smell in the car 05 wrx wag
