Oil starvation due to oil pickup tube snapping off...
Car Info: Silver 06 STI - Helix catted dp - Cobb stage 2
My motor is in pieces at the shop right now. Went in to look at it and they showed me that the damage was only to the #1 rod bearings and the crank shaft. What a bummer though because the car only has 23,000 mi and it's getting major heart surgery. They said they are going to replace the main bearings, rod bearings, crank, the one rod that got super-heated, and they're throwing in the piston rings at my request. I'm happy that they're doing it right, but still wondering whether I should keep it or sell it. Curious what others would do. I'll have it back next week.
BanHammer™
Car Info: 2001 Forester RS2 SPEC-F
definately, but then you're back to square one with breaking it in...
and plus with new engine components, you're always gonna be listening to the engine for noises..."wait, what was that noise" or "oh, that didn't sound good"
Yup, I'm going to be super paranoid. It's be nice if I could have them throw in some forged light weight pistons and make it ready for some serious upgrades once it's out of warranty.
BanHammer™
the pistons will expand under heat so when the car is cold, there is a lot of piston slop until the engine comes up to temperature. When this happens, there is more then normal ware on the piston and block. Forged pistons are meant to be used on vehicles that are started up and run for a long period of time or not used very often.
semi-forged pistons are perfect for a street vehicle since they do not have the same expansion characteristics that the fully forged pistons exhibt.
Yes, they were pretty cool about it. They had me bring in my records to show that I had changed the oil and all that. I have a written record and receipts. I was surprised to find that I had changed the oil 10 times already. I always use mobile 1 to try and avoid situations like this. Once they found the oil pickup tube had snapped from probably being overheated when it was braised on, they let up on their semi-suspiscious tone and all was good.
PROTIP: forged pistons do not work very well on daily drivers.
I just read up on forged vs. semi-forged. It seems that forged don't expand as much but they expand faster. This is a problem if you get on it before the motor is properly up to temp as seizing can occur so they need bigger tolerances. As far as semi-forged goes - one guy said all cast pistons are semi-forged. Don't know how correct that semi-forged statement is.
