Need Help: Removing broken bolt from chassis, Can i drive without a RSB?
Old 07-25-2009, 11:29 AM
1FSTREX's Avatar
Car Info: 2018 STI Limited
Dude how is everywhere closed on a saturday in this economy??!!?!?
1FSTREX is offline
Old 07-25-2009, 11:37 AM
RussB's Avatar
Car Info: $200,000 sports car
rivet nut if you can...
i had a similar situation happen with my drivers seat mount. there ended up being a TSB because they used such a crappy lock washer that the drivers seats would come loose periodically.
well, prior to this TSB, i took mine in to be repaired and all they did was tighten the ****ing bolt. i asked what to do if it comes loose again and they said "just tighten it yourself if you have a socket set". well, next time i tried it the head snapped off.
so, i pulled the seat, drilled out the broken bolt, jacked up the threaded hole. i installed an appropriate size / grade rivet nut at that hole and re-installed the seat using SAE grade 10.9 bolts, fender washers, and blue loctite. seat never had a problem again.
RussB is offline
Old 07-25-2009, 11:42 AM
1FSTREX's Avatar
That is what i am thinking about getting done.
honestly i have screwed this up so much its time to just let the professionals do it.
Whats really throwing me off is that the hole is right next to the fuel inlet pipe, so i cant get a straight shot with my drill.
1FSTREX is offline
Old 07-25-2009, 01:16 PM
RussB's Avatar
would it help if you got a 90 degree drive?
RussB is offline
Old 07-25-2009, 01:19 PM
1FSTREX's Avatar
You know that might work, i might have to go out and get one of those and try.
1FSTREX is offline
Old 07-27-2009, 08:10 AM
iClub Silver Vendor
FW Motorsports's Avatar
Car Info: 2005 LGT wagon
Don't Believe the Hype!!
FW Motorsports is offline
Old 08-07-2009, 02:18 PM
1FSTREX's Avatar
Cars finally fixed!
1FSTREX is offline
NiNe7-Gxe
04-24-2014 07:03 AM
fotifo
12-08-2006 11:27 AM
BoostBuddy.com
Engine and Drivetrain
06-13-2006 03:21 PM
Aegon
06-15-2005 04:34 PM
DrunkenMonkey
05-31-2005 04:13 PM
Quick Reply: Need Help: Removing broken bolt from chassis, Can i drive without a RSB?
Top
