WTB: 07 EJ25/GD STI bits and parts (ongoing)
I am starting thing thread to better differentiate between my "02RS25's RSTI Swap" thread to keep this for parts needed for my bbuild, and the other thread for proj updates.
As stated, im looking for those of you that have boxes of random bits and pieces that where once powering an EJ25. this mean anything from casebolts to OEM turbo and onward. this will be an ongoing thread as I expect my total swap to take 2-5 years and will need parts as I go along with the build. some parts will be brand new, some will be used.
So, where all you pack rats at!?
Ill be starting to look for sti heads for the build. Even heads without cams work. Should I buy used heads, idnlike to get the heads machined regardless. That being said, ncan any of you reccomend good shops in the bay area? Ive taken a look arpund via web, but im sure there are a few of you on here that can point me in the direction of good quality work with prior subaru surfacing experience.
TIA
TIA
All out of my 07:
Rods
Headers
Up Pipe
Engine Mounts
Tranny Mount
Alternator cover
Walbro 255 Fuel pump
Air Intake Box/Pipe
Resonator Box that goes in Fender
I am sure there is more, that's just what I can see in the garage so far.
Rods
Headers
Up Pipe
Engine Mounts
Tranny Mount
Alternator cover
Air Intake Box/Pipe
im looking to build up shortblock first. so right now im looking for misc shortblock related items. i.e case bolts (will be using new bolts in finnal build), wrist pin plugs, etc.
PM me, both of you, with parts that can start me building the shorty. after that, ill most likely be coming back for other parts if needed. as stated before, on a tight budget on this build and expect it to take time. so im trying to buy parts related to the stage in the build im at (short block assembly, heads assembly, long block assembly, pulleys, belts, turbo, etc.)
also, as a side note to this thread, ive seen a couple people on here selling BNIB parts that never made it to their build. you guys are welcome too!
thanks again everyone for the help. as stated before, im super stoked about building up this STI and throwing it in my BRP bugeye. of which im trying to go for a bit of a "sleeper" look. i think i may run FMIC (want TMIC frist) and RS (scoopless) hood and wingless. teehee
have a great day!
TIA
TIA
Bumping this post one more time.
Long story short, im going to have to shift from STI to RS head rebuild. I recently found out i have an internal head gasket leak (exhaust in coolant!) that being said, i am going to have to pull engine, machine heads (i hear different suggestions. machine? or dont machine? SOHC) and rebuild heads myself (new stem seals, sleeves, shims, etc.)
any reputable shops arounf the area. i have a few places noted down i will be looking at this week. but prior subaru head machining experience a plus!
** Keep thos STI parts coming!
schweet. im not quite to the chassis build yet. but do PM me a price and pics if possible. again, no rush. but i am distantly interested....ifthat makes ANY sense.
BUmpity
I will be looking for a set of used B25 head for my STI engine. if anyone has a set of used B25's that need a bvalve job/ rebuild, PM me!
Also, thanks JVblk for hooking it up. still have to go pick them up. but a great score!
epyon08
11-05-2014 08:18 AM
SpeeDyScooBy
05-30-2013 02:49 PM
macker
07-30-2012 02:00 PM
keirnna
02-05-2005 02:38 AM
