Whiteline MAX-C Adjustable Front Camber Strut Top w/ STi Grp N Rear Mounts COMBO!
Specially engineered with COM12 type bearing that is 40% higher load rating than other popular options. Fully serviceable and held in by threaded collar so no rattle. Height change minimized with average of +3 mm depending on camber setting (roughly -2.0 mm to +7.5 mm). Other most popular types range between +12 mm to +19mm height increase.
The slot is a combination adjuster that moves from a maximum achievable caster to max achievable camber WITH caster. The Max-C range is named for the ability to achieve Max caster and or Max camber, more than anything else on the market. You run at Max caster position for street and then simply slide to Max camber for track. Street and Motorsport versions are available that are designed to work with stock or coil-over format springs. That is, street kit is limited to stock spring OD clearance, motorsport kit designed for coil-over spring so have a lot more range.
Application: 02+ WRX/04+ STi
Part Number: KCA251S
MSRP: $332.
Special Introductory Offer: $295
**Free Shipping**
We can also package this up with STi group N strut mounts
04+ STi rear strut mounts (pair) - add $185 free shipping
02-03 STi rear strut mounts (pair)- add $160 free shipping
Thank you!
edzwrx
07-20-2012 11:52 PM
GoodTimes
03-01-2010 09:13 PM
Speed Element
01-22-2007 12:00 PM
