New JDM Parts Fresh off the Boat! Cusco Zero2E, JDM STi seats, JDM H6 Motors & MORE!
Brand New Cusco Zero-2E & E-Con Package 02-05 WRX & 04 STi
SOLD ! IN STOCK READY TO SHIP !
With great features such as:
- Electronically controlled shock adjustment (w/ E-Con)
- Pillowball upper mounts
- Adjustable shock casing
- Independent adjustable spring perch
- Stainless steel thread body
- Stainless steel case lock nut
- Stainless steel spring perch/lock nut
- Specially coated lower bracket
Cusco developed a new shock absorber for the Zero-2E that further reduces friction resistance of the dampening force to achieve high performance with the vehicle lowered.
- New design: Side port rotary valve
- New: Reduced friction piston
- New oil reducing cavitation
- New material: Special steel for piston valve shim
The E-Con uses high quality adjustment motors to control the rebound force quickly and accurately. The motor utilizes a special rubber cover to shield itself from moisture caused from the extreme humidity and temperatures found in the engine bay. Installation is a cinch with the specially designed bracket on the Zero-2E coilovers.
JDM STI TMIC + y-pipe & hose
$600 shipped ! IN STOCK READY TO SHIP !
Less than 500km
2003 Legacy H6 (that's right 6-cylinder) engine!
$1699 + shipping ! IN STOCK READY TO SHIP !
QTY: 7
-Less than 500 miles
-Great for project cars are sandrails
-Rumor has it JUN Japan is currently using this type engine for a 800whp car
JDM WRX motor
$1599 + shipping
Qty 5
-Less than 1000KM!!
-2.0 Liter, AVCS, JDM Motor
-Higher compression than USDM motor
-Long Block includes all pumps, sensors, intake manifold etc
-no injectors/turbo/intercooler
-This motor features more aggressive AVCS cams and higher compression. With a JDM ECU - YOU WILL MAKE MORE POWER!!![Smilie](https://www.i-club.com/forums/images/smilies/smile.gif)
Forrester FXT EJ25 Engine with the cam sensor adapter
$2999 + shipping
Qty 5
-Less than 1000KM!!
-2.5 Liter, AVCS, etc.
-Guys this is essentially a NEW USDM EJ25 STI engine, minus the red intake manifold. The real difference between the FXT and the USDM STI is tuning, turbo size, and intercooler size.
-We will even throw in a USDM STi red intake manifold FREE
![](http://www.gruppe-s.com/Clearance/FXT-MOTOR1.jpg)
Here's a dyno chart with the FXT motor with a VF30 on 91 octane.
![](http://www.gruppe-s.com/Clearance/FXT-withVF30.jpg)
JDM STI V8 FRONT & REAR SEATS w/ pass through
$1199 + shipping ! IN STOCK READY TO SHIP !
Regards,
Preston
Gruppe-S Engineering
29150 Simms Ct.
Hayward CA 94544
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
![](http://www.gruppe-s.com/Clearance/CUSCOZERO2E.jpg)
![](http://www.gruppe-s.com/Clearance/ECON.jpg)
Less than 500km
![](http://www.gruppe-s.com/Clearance/JDMSTI-TMIC1.jpg)
![](http://www.gruppe-s.com/Clearance/JDMSTI-TMIC2.jpg)
QTY: 7
![](http://www.gruppe-s.com/Clearance/EZ30.jpg)
JDM WRX motor
$1599 + shipping
Qty 5
-Less than 1000KM!!
![](http://www.gruppe-s.com/Clearance/JDM-EJ20WRX.jpg)
$2999 + shipping
Qty 5
-Less than 1000KM!!
![](http://www.gruppe-s.com/Clearance/V8FRONT.jpg)
![](http://www.gruppe-s.com/Clearance/V8REAR.jpg)
Regards,
Preston
29150 Simms Ct.
Hayward CA 94544
We Accept Paypal!
product name: XXXXX
sales rep: Preston
Shipping address.
JDM heads ! !
$1499 + Shipping
Hey guys,
We received some JDM heads that has had an advanced type of knock-detection device installed on these before. The heads have been pre-drilled so that a knock sensor can be installed directly into the combustion chamber. You can plug these wholes with a screw or install your own sensors. We’re not sure what type of sensors were used. These heads are AVCS and that they can be used on a non-AVCS car with modifications.
The heads feature big-port JDM heads, V7 high lift cam-shafts, and JDM STI valve-train. These heads are good for revving up to 8500 RPM and are perfectly suited for larger turbo applications do to the more aggressive duration and high rev capability.
NOTE: The heads must be inspected and all bolts RE-TORQUED to specifications before installation.
Regards,
Preston
29150 Simms Ct.
Hayward CA 94544
We Accept Paypal!
product name: XXXXX
sales rep: Preston
Shipping address.
$1499 + Shipping
![](http://www.gruppe-s.com/Clearance/jdm-heads1.jpg)
![](http://www.gruppe-s.com/Clearance/jdm-heads2.jpg)
Hey guys,
Regards,
Preston
29150 Simms Ct.
Hayward CA 94544
We Accept Paypal!
product name: XXXXX
sales rep: Preston
Shipping address.
gruppe-s
Engine and Drivetrain
17
11-29-2005 12:51 PM
