FS: Power Enterprise 565cc "Pink" Top Feed Fuel Injectors (WRX) + Timing Belt Guide
Car Info: MY00 GC6 BRP
The original sheet metal timing belt guide can flex from belt deflection when subjected to extreme RPMs causing the timing belt to skip one or more teeth on the crankshaft sprocket. The Timing Belt Guide was developed to control this problem and is machined from solid aluminum with a hard anodized finish. Includes mounting hardware.
