FS: Gram Lights 57F Pro 18x7.5x42offset
Car Info: 2004 WRX Wagon, 5 Speed, SRM.
FS: Gram Lights 57F Pro 18x7.5x40offset
I have a set of Gram Lights for sale, specs are as follows:
57F Pro (2 piece, Gunmetal 5 Spoke, Polished Lip)
Size: 18 inch by 7.5 inch wide
Bolt Pattern: 5x100
Offset: 40 (Runs fine with no ill effects to bearings, only hitch would be if you decided to run significantly larger breaks, you would have to look into fitment)
They come with tires, although the tires are not great (215 40 18) m+s rated, with appx. 50% tread left.
Two of the wheels have been scratched along the lip (previous owner) however, all are perfectly balanced with lead tape on the inside of the lip.
Below are some pictures, and I can get more within a few days if you need.
EDIT: Price: 1200 picked up.
Shoot me a pm if you have any questions
Bolt Pattern: 5x100
