FS: 2002-2003 WRX parts
Car Info: 2007 silver STI
Parts from 2003 wrx wagon.
-front drivers side wheel hub and housing $50
-HVAC control assembly $30
-HVAC blower/heater/ac box assembly including heater core, ac evaporator, blower $100
-Upper dash board with hvac ducting, and vents (drivers side adjustable vent missing) with passenger side airbag. $100
-drivers side front and rear window motor/assembly (motor and metal, no glass.) $30 each
-all 4 interior door cards, including window switches. $75 for the set
-Power steering rack.$50
-Brake master cylinder/vacuum booster $50
-ABS hydraulic block (the big block that all the brake lines go into.)$50
-Stock WRX flywheel
All prices are negotiable.
This is everything I have. I will remove parts as they sell. If it isnt listed above, I dont have it!
-Stock WRX flywheel
Now that i think about it... that starter motor might actually be from a 2002 2.5 rs... (i did a swap a while back and these are parts I have left) ill have to look into it for you and figure out which motor it is.
Sorry for the delayed response, I didn't get the email that there was a post! The color is the stock wrx color for those years. Mostly black with the bluish weave insets. Don't have any other interior parts than the ones listed.
