Cusco and STi suspension parts back in stock. Tein, Wilwood, brake clearance...
Cusco!
Cusco Type OS Strut Tower Bar - 02+ WRX / 04+ STi
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. Cusco Type-OS improve chassis rigidity and reduce this flex. Lightweight aluminum and high rigidity oval sectioned pipe used.
$150 shipped for Front
$150 shipped for Rear
$290 shipped for Both
Cusco Type OS-T Triangle Brace - Rear - 02+ WRX / 04+ STi
*Only includes the triangle brace, not the rear strut tower bar.
$125 shipped
$265 shipped w/ Type OS Rear Bar (as pictured below)
Cusco Type OS Strut Tower Bar and Triangle Brace - Front and Rear Combo - 02+ WRX / 04+ STi
$410 shipped
Cusco Sway Bars - 22mm F / R - 04+ STi
-The addition of stiffer swaybars properly distributes cornering forces by reducing lateral sway applying increased cornering force on the outside wheel and will ultimately increase vehicle turning characteristics. The rear sway bar will promote rotation at the rear of the car, while the front sway bar will promote rotation at the front of the car.
$155 shipped for Front!!!
Cusco Sway Bars - 21mm F / 22mm R - 02+ WRX
$155 shipped for Rear!!!
$300 shipped for Both!!!
$239 shipped for Rear with Helix WRX Rear Endlinks (Full Pillowball) - 02+ WRX
$265 shipped for Front with Perrin WRX Front Endlinks (Full Pillowball) - 02+ WRX
$494 shipped for Both with Perrin WRX Front Endlinks and Helix Rear Endlinks - 02+ WRX
Cusco V2 Lower Arm Bar - 02+ WRX / 04+ STi
-The purpose of the Cusco lower arm bar is to reduce alinement flexing and improve body rigidity. The lateral arm improves body and rigidity by connecting at the lower arm points. Thus preventing body flex and therefore dramatically improving steering, throttle response and traction. The Version II Bar mounts by multiple bolts and the lateral and foe aft rigidity is greatly increased over Version I.
$150 shipped!!!
Cusco Rear Suframe Brace and STi Rear Diffuser- 02+ WRX / 04+ STi
-Rear subframe brace is designed specifically for STi rear diffuser.
-Allows easy installation of 06 STi rear diffuser on 02-05 MYs.
-Stiffens chasis resulting in crisper vehicle dynamics and improved handling.
$249 shipped
STi items:
STi Pink Springs - 04+WRX/STi
-Designed by STi to work with your stock Struts
-Doesn't lower your car too much: -.5" all around for STi, -1" all around for WRX.
-Will retain excellent ride quality while lowering car's center of gravity for increased handling prowess.
-Spring rates: Front: 258 lbs/in; Rear: 218 lbs/in
$379 shipped!!!
STi Group-N Strut Top Mounts - 04+ WRX / 04+ STi
-Stronger version of the stock style upper mounts. Hardened material increases suspension response by reducing flexing and camber changes. Good intermediate modification to maintain streetability over full-blown metal pillowball upper mounts. Easy bolt-on installation with no modifications necessary.
*Front Strut Top Mounts will work for all WRX model years.
$110 shipped for front!!!
$185 shipped for rear!!!
$279 shipped for F and R!!!
STi Group-N Strut Top Mounts and STi Pink Spring Combo - 04+ WRX / 04+ STi
$639 shipped!!!
Thanks,
Preston
Phone: (510) 783-5300
We Accept Paypal!
Paypal: sales@gruppe-s.com
When ordering w/ paypal, please include the following:
product name: XXXX
sales rep: Preston
Price including shipping: $XXXX
Shipping address.
$125 shipped
$410 shipped
$150 shipped!!!
$249 shipped
STi items:
$379 shipped!!!
$639 shipped!!!
Thanks,
Preston
We Accept Paypal!
product name: XXXX
sales rep: Preston
Shipping address.
Hey guys,
We're cleaning out our warehouse so we've got some cool stuff for some really good prices. All of this stuff is in stock and ready to ship.
Wilwood 6-piston Front (Drilled Rotors) - 02+ WRX
$1345 Shipped
*6-piston billet aluminum calipers
*12.9" 2-piece rotors (cross-drilled rotors)
*High performance brake pads
*All mounting hardware included
*Requires 17"+ wheels
*Brake lines are NOT included (add $150 for SS lines)
Tein Flex Coilovers - 02+ WRX / 04 STi ONLY
$1529 Shipped
$1859 Shipped w/ EDFC
*Independently height adjustable
*16 way dampening adjutable
*EDFC compatible
*Pillowball mounts all 4 corners (camber adjustable in the front)
*8 KG F / 7 KG R spring rates
Cusco Zero1 - 02+ WRX / 04 STi ONLY
$1699 Shipped
*7 KG F / 5 KG R spring rates
STi Replica Strut Tower Bars - 02+ WRX / 04+ STi
$75 Shipped for Front
$60 Shipped for Rear
$125 Shipped for Both
Suspension upgrades such as high performance springs, shocks and tires can add additional stress to the chassis resulting in additional chassis flex. These STi Replica Strutbars improve chassis rigidity and reduce this flex. By using a monocoque aluminum tube shaft, high strength and rigidity are obtained without unnecessary weight gain.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
$1345 Shipped
$1529 Shipped
*EDFC compatible
$1699 Shipped
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
We're excitied to announce that we just got some of the first sets of Performance Friction 2-piece replacement rotors in for the STi. Performance Friction is well established in the racing scene and these rotors look the part. They're also very affordable. Best of all, the hats are drilled for 5X100 and 5X114.3 so the 05 STi guys can finally have some fun.
Peformance Friction 2-Piece Replacment rotors for 04+ STi -
Special introductory price of $699 Shipped!!!
-5X100 and 5X114.3 fitment!
-2-piece design allows aluminum hat for lightweight rotors.
-Full floating design allows expansion of rotor and hat at different rates to prevent pad coning.
-Lightweight - 17.6 lbs per rotor (stock rotors are 22 lbs.).
-Dimpled to increase surface area of rotor (promotes cooling), refresh pads, and less prone to cracking than cross drilled rotors.
-Vaned to promote cooling.
-Allows you to retain stock Brembo calipers
And a special introductory package:
Porterfield R4-S Pads F, Peformance Friction Rotors F, Goodridge SS lines F+R: $1069 shipped!!!
Endless SSS Pads - 04+ STi, F/R
These pads are an excellent choice for the agressive street driver. They are non-metalic so they are rotor friendly and dust is minimal. The SSS feature a high friction coefficient so they are suitable for short weekend track stints but are not applicable for heavy track use.
$160 shipped for F or R, $300 shipped for F and R!!!
Porterfield R4-S Brake Pads (carbon kevlar), 04+ STi, F/R
These pads are a good balance between race pads and street pads. The Porterfield R4-S’ are unique because they’ll withstand 20 minutes of track time with no fade (they so not fade at temperatures up to 1,100 degrees F) but at the same time, they will work fine when cold and they’re very rotor friendly (as well as being very slow wearing). The R4-S friction level will give you an impressive increase in stopping ability with very minimum pedal effort. The R4-S compound also has the absolute lowest noise and dust levels, far below OEM equipment or any other high performance brakes material.
Good for autocrossing, drivers schools, weekend track sessions, solo events, and rallys.
$199 shipped for F, $269 shipped for F and R!!!
Brembo Sport Replacement Rotors (Drilled or Slotted) - F/R - 04 STi only
~Brembo Sport slotted brake rotors are for drivers who want to improve the
looks and performance of their vehicle's original braking system without
having to change additional brake components.
~Brembo Sport slotted and drilled brake rotors provide excellent stopping
power in everyday traffic, as well as high performance street and track
driving.
~Brembo Sport slotted brake rotors match the vehicle's original equipment
rotor's dimensions and are fully compatible with its hubs, brake calipers
and road wheels.
$394 shipped for F, $375 shipped for R!!!
OK, now for the packages:
04 STi Front:
1) Porterfield R4-S Pads F, Brembo rotors F, Goodridge SS lines F+R: $675 shipped!!!
2) Endless SSS Pads F, Brembo rotors F, Goodridge SS lines F+R: $655 shipped!!!
3) Porterfield R4-S Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1110 shipped!!!
4) Endless SSS Pads F+R, Brembo rotors F+R, Goodridge SS lines F+R: $1180 shipped!!!
Special Brake Packages for the WRX:
Gruppe-S finally carrys Motul Fluid! People have been asking for some cheap effective brake combos for their WRXs for quite some time now. This is the most cost effective way to improve your brakes.
Porterfield R4S Pads + Goodridge SS Lines + Motul RBF600 Fluid
*The Goodridge Stainless Steel Brake Lines will improve your pedal feel and stop unwanted line flex at high temp.
*The Porterfield R4S Carbon Kevlar Brake Pads have a superior coefficient of friction compared to the stock pads and have excellent fade characteristics. They'll take 20 minutes of weekend track time for beginner to intermediate drivers with no ill effects
*2 Pints of Motul RBF600 Brake Fluid are more than enough to flush your entire brake system. This is some of the best brake fluid out there (DOT4) and is track worthy stuff.
All 4 Corners for 02 WRX - $299 Shipped
All 4 Corners for 03+ WRX - $319 Shipped
If there's a package that you'd like and it's not listed, please don't hesitate to ask for pricing.
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
driving.
and road wheels.
04 STi Front:
Thanks,
Mark
We Accept Paypal!
product name: XXXX
Shipping address.
Speed Element
05-02-2007 07:50 PM
Speed Element
12-11-2006 12:36 AM
gruppe-s
05-03-2006 02:01 PM
gruppe-s
04-12-2006 08:14 PM
gruppe-s
04-12-2006 08:10 PM
